Vista - BSoD - trouble finding solution...
Old 09-25-2008   #1 (permalink)
Vista ultimate 32 bit
hi,
I am having trouble fixing a BSoD problem i keep getting on my laptop. The problem arises when I have put the laptop on standby and try to wake it again. I get the following error code:
0x0000007e (0x000001D, 0x8FFA4F76, 0x969CD51C, 0x969CD218)
I have tried searching the internet for a solution on the 7e error code, and I keep finding that the solution is the KB929777 is to be installed, but it says it's not relevant for my computer when trying. I have the SP1 installed through the windows update, so I am kinda running out of ideas.
Anyone have any solutions to this problem?
Thanks in advance.
Old 09-26-2008   #2 (permalink)
Re: BSoD - trouble finding solution...
Anyone know something about this problem?
Old 09-26-2008   #3 (permalink)
zachd [MSFT]
If you use Hibernate instead, does that work better?
I believe this:
http://msdn.microsoft.com/en-us/library/ms795746.aspx
is more relevant than the KB article you referenced.
Speaking for myself only.
See http://zachd.com/pss/pss.html for some helpful WMP info.
"Darkon" <guest@xxxxxx-email.com> wrote in message
news:092e63ee03577546691ddd54fdcba687@xxxxxx-gateway.com...
Quote:
> hi,
> out of ideas.
> Thanks in advance.
> Darkon
Old 09-29-2008   #4 (permalink)
Cheers, thanks for the answer.
The article you refer to are proberly more relevant, I am however not keen on trying to debug it myself.
For some reason the problem has stopped by itself again. I might try and change some drivers lniked to memory, as it could be a problem with the computer saving to memory when going in to standby.
Trouble with finding a space useing Instr VB Script
trouble finding sata driver Drivers
Need help finding a GOOD backup solution Software
Trouble Finding Text in Windows Mail Vista mail
How to disable 'Windows is checking for finding a solution to the problem" Vista General
