| | Toshiba L305-S5884 wireless card and hard drive issue on Vista I bought a brand new Toshiba Satellite L305-S5884 (Vista SP1) from Fry's electronics on Sunday (9/21/08) 1) I turned it on and sat it right next to my wireless router and it did not see it. It saw both my neighbors routers, but not mine. My other laptop, a Sony Vaio VGN-NR498 (two months old) saw the wireless router just fine. I called Toshiba and some woman in the Phillipines told me to disable then reenable it. That didn't work. Then she made me uninstall and reinstall it. That worked. For a while. It saw it, connected, then stayed connected for about 1/2 hour, then lost the connection. I reconnected and it stayed, then lost it. I gave up and plugged the CAT 5 into the laptop. I turned the router and laptop off, then router back on, then laptop back on and it worked. I am on the road this week and I can see and connect to wireless networks just fine. Is my wireless card bad? 2) I decided to do a CHKDSK and it froze at 55% of stage 5. I figured oh well. I took the battery out, restarted and it started the CHKDSK and once again, it stopped at the exact same cluster. I called Toshiba and they said I probably have a bad hard drive. Is my hard drive bad? |
| | Re: Toshiba L305-S5884 wireless card and hard drive issue on Vista "ca" <ca@xxxxxx> wrote in message news:16A2699D-667D-42CB-A4B4-C8B64FF70878@xxxxxx Quote: >I bought a brand new Toshiba Satellite L305-S5884 (Vista SP1) from Fry's > electronics on Sunday (9/21/08) > 1) I turned it on and sat it right next to my wireless router and it did > not > see it. It saw both my neighbors routers, but not mine. My other laptop, > a > Sony Vaio VGN-NR498 (two months old) saw the wireless router just fine. I > called Toshiba and some woman in the Phillipines told me to disable then > reenable it. That didn't work. Then she made me uninstall and reinstall > it. > That worked. For a while. It saw it, connected, then stayed connected > for > about 1/2 hour, then lost the connection. I reconnected and it stayed, > then > lost it. I gave up and plugged the CAT 5 into the laptop. I turned the > router and laptop off, then router back on, then laptop back on and it > worked. I am on the road this week and I can see and connect to wireless > networks just fine. Is my wireless card bad? > > 2) I decided to do a CHKDSK and it froze at 55% of stage 5. I figured oh > well. I took the battery out, restarted and it started the CHKDSK and > once > again, it stopped at the exact same cluster. I called Toshiba and they > said > I probably have a bad hard drive. Is my hard drive bad? > Take it back to Frys. bw.. |
| Toshiba 250gb External Hard Drive | Vista hardware & devices | |||
| Ghost Icon for USB Toshiba External Hard Drive | Vista hardware & devices | |||
| Vista Hard Drive Issue! | Vista hardware & devices | |||
| Hard Drive Issue and Vista | Vista hardware & devices | |||
| Issue with Vista detecting Waveplus wireless card | Vista hardware & devices | |||
