Hard drive running
  1. #1
    JBrown Guest
    Hard drive running
    I just got a new PC with Windows Vista home premium. The hard drive seems to
    be running allot. Is this normal for Vista?
    Thank you,(jbrown15@xxxxxx)
    Jim Brown
  2. #2
    Bill Davis Jr Guest
    Re: Hard drive running
    On Sat, 27 Sep 2008 10:43:49 -0400, "JBrown" <jbrown15@xxxxxx>
    Yes. It will do this for awhile. It is Indexing the files on your
    computer to find them faster. Just let it run it will stop.
  3. #3
    Paul Montgumdrop Guest
    > seems to be running allot. Is this normal for Vista?
    It's just doing the file indexing. Vista and indexing are setup to only
    index 3 default folders out of the box. Vista is not indexing the entire
    drive, unless you start changing the Index service configuration. You
    can look the information up, use Google. Just let it run, it will stop
    and it's not doing it all of the time once it does its initial indexing.
  4. #4
    +Bob+ Guest
    On Sun, 28 Sep 2008 06:56:46 +0800, fatsteve <internet@xxxxxx> wrote:
    >> In theory is should improve how fast search finds things. Since most
    >> people rarely if ever do extensive searching for files on their system
    >> all the effort is wasted. Most people disable indexing or limit it to
    >> one partition.
    >yeah turn it off, its worthless. search works just fine without it.
    Or better yet, download Agent Ransack (google it) and use that.
    I shut off indexing on all drives, but one day when there was vigorous
    disk activity (not due to me doing anything) I checked in process
    explorer and found the searchindexer.exe was still running wild. I
    renamed the executable and that seems to have solved the problem.
Hard drive running problems?
Hard drive running like crazy for no reason Brian88135 General Discussion 11 03 Jul 2009
Hard drive running -- yet another thread FactsOnline Vista General 0 05 May 2009
Hard drive never stops running chaseme5 Vista hardware & devices 8 31 Jul 2008
Hard Drive continuously running Marty Vista General 4 03 Apr 2007
pc freeze and hard drive keep running =?Utf-8?B?a2ltdHUx?= Vista General 1 08 Oct 2006
