Vista - System restore and hard drive with two partitions
Old 09-29-2008   #1 (permalink)
RJ
Hi, i have an Acer 8920 laptop which has a 320 Gb HD. In computer this
capacity shows up as 2 drives (c: acer and d:data). When configuring system
restore should i create restore points for both drives or just the drive
with windows on it (C?
Old 09-29-2008   #2 (permalink)
Rosco P Coltrane
Re: System restore and hard drive with two partitions
system restore only restores system files, and program files...
if you just use D as storage of your own personal files (documents, videos,
downloads etc)
then there is no reason why you would want to create restore points there.
I personally have only C, and did the same with XP (that automatically
monitored all drives by the way)
"RJ" <rob.@xxxxxx> wrote in message
news:md8Ek.47219$FS.9234@xxxxxx
> system restore should i create restore points for both drives or just the
> drive with windows on it (C?
Old 09-29-2008   #3 (permalink)
David B.
Disable monitoring on the second partition.
Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm
How to ask a question http://support.microsoft.com/kb/555375
Help Us Help You http://dts-l.net/goodpost.htm
Old 09-29-2008   #4 (permalink)
Mike
My Toshiba has C: for Vista and D: for Toshiba. I think the D: drive is for
Toshiba firmware. Shouldn't I System Backup it too? I do take image
backups for both drives. I have done System Restores where both logical
drives were restored successfully.
I'm assuming RJ's situation is the same as mine: His C: for Acer firmware
and D: for his OS. Maybe I'm assuming too much and C: is really Vista and D:
is Docs, Pics, etc. Perhaps he can clarify that.
"David B." <mail@xxxxxx> wrote in message
news:er4wa1lIJHA.2208@xxxxxx
Old 09-29-2008   #5 (permalink)
RJ
"Mike" <lagunasrfr@xxxxxx> wrote in message
news:OXJIDDmIJHA.3816@xxxxxx
> for Toshiba firmware. Shouldn't I System Backup it too? I do take image
> D: is Docs, Pics, etc. Perhaps he can clarify that.
Thanks for the replies. My C: is for Vista and everything else as far as i
can see. The D: partition doesn't seem to get used and i don't know how to
save photos, documents etc to it.
Old 09-29-2008   #6 (permalink)
Richard G. Harper
The D: partition is almost surely the "recovery" or "restore" partition that
can be used to restore your computer to factory-new state. You should check
your manual, the documentation that came with your computer, or the
manufacturer's web site to confirm this.
Richard G. Harper [MVP Shell/User] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
news:NQaEk.44497$fd.18115@xxxxxx
Hard Drive Partitions Vista General
Solved no user partitions after system restore General Discussion
OT: Boot issues after Ghost System Partition Restore to New Hard Drive Vista General
System Restore ate my hard drive Vista General
7200 rpm Ultra-IDE hard drive loud during automatic system restore Vista hardware & devices
