| Vista Home Basic | Help Media player 11 I was running IE7 with Media player and all was fine... I (stupidly!!!) decided to install IE8 Beta. My media player worked fine, but I couldn´t open a banking page, so I had to remove IE8 and revert to IE7, which is where my problems started with Media player 11. I now cannot run live streaming of programs from RTÉ Ireland's National Television and Radio Broadcaster. They load in the buffer but then the screen stays black and just says ready. (I know that all network connections are ok). I tried to uninstall WMP 11, but apparently it is an integral part of Vista so no can do. I also tried reinstalling WMP 11 but it keeps saying that a newer version is installed, any ideas?? I also have Real Player but this doesn't run as smoothly (as WMP did!!) And I hope the solution is not to reinstall Vista, that sounds like the days of NT4, when MS had just one answer to every questoisn they got on any program, you have to reinstall NT!!!! Thanks Noel |
| VISTA HOME PREMIUM X64/ 7 x64 / 7x86 | Re: Help Media player 11 I was running IE7 with Media player and all was fine... I (stupidly!!!) decided to install IE8 Beta. My media player worked fine, but I couldn´t open a banking page, so I had to remove IE8 and revert to IE7, which is where my problems started with Media player 11. I now cannot run live streaming of programs from RTÉ Ireland's National Television and Radio Broadcaster. They load in the buffer but then the screen stays black and just says ready. (I know that all network connections are ok). I tried to uninstall WMP 11, but apparently it is an integral part of Vista so no can do. I also tried reinstalling WMP 11 but it keeps saying that a newer version is installed, any ideas?? I also have Real Player but this doesn't run as smoothly (as WMP did!!) And I hope the solution is not to reinstall Vista, that sounds like the days of NT4, when MS had just one answer to every questoisn they got on any program, you have to reinstall NT!!!! Thanks Noel You might like to try a system restore to a point before you installed IE8 System Restore - How to Hope this helps SIW2 |
| | Re: Help Media player 11 Does the standalone Media Player still function? I'm curious if this is a general player breakdown or only of streaming media functionality. Are you on a 64bit or 32bit system? Does this system have Vista Service Pack 1 applied? -Zach -- Speaking for myself only. See http://zachd.com/pss/pss.html for some helpful WMP info. This posting is provided "AS IS" with no warranties, and confers no rights. -- "Noelito" <guest@xxxxxx-email.com> wrote in message news:913c60bfafa51af77927bc741c6412a3@xxxxxx-gateway.com... Quote: > > I was running IE7 with Media player and all was fine... > > I (stupidly!!!) decided to install IE8 Beta. My media player worked > fine, but I couldn´t open a banking page, so I had to remove IE8 and > revert to IE7, which is where my problems started with Media player 11. > I now cannot run live streaming of programs from 'RTÉ Ireland's National > Television and Radio Broadcaster' (http://www.rte.ie/live). They load in > the buffer but then the screen stays black and just says ready. (I know > that all network connections are ok). I tried to uninstall WMP 11, but > apparently it is an integral part of Vista so no can do. I also tried > reinstalling WMP 11 but it keeps saying that a newer version is > installed, any ideas?? > > I also have Real Player but this doesn't run as smoothly (as WMP did!!) > > > And I hope the solution is not to reinstall Vista, that sounds like the > days of NT4, when MS had just one answer to every questoisn they got on > any program, you have to reinstall NT!!!! > > Thanks > > Noel > > > -- > Noelito |
| Playing Vob Files In Media Player 10 + 11 - Chơi file vob tręn Media Player 10 + 11 | Vista General | |||
| Windows media player stops working when I plug in my MP3 Player | Vista General | |||
| Windows Media Player Playlist - load to player without using Sync? | Vista music pictures video | |||
| KMplayer, the media player that puts Windows Media Player to SHAME! | Vista General | |||
| DVD player stops working if you eject when Media Player is open | Vista music pictures video | |||
