Vista - Virtualisation problem
Old 09-30-2008   #1 (permalink)
JohnNorth
Hi
What is the strategy under Vista to store system wide data for an application?
I've encounter a problem moving my application from XP to Vista. The file
virtualization didn't work for me as the program writing the file is a
service and thus not interactive.
I need a folder on the box that two applications can access. Is it just a
case of keeping out of the new protected area's (e.g. program files) or is
there a strategy for this. I don't want to store the files on a per user
basis. These files are data files and not configuration files.
Old 09-30-2008   #2 (permalink)
Mark L. Ferguson
Re: Virtualisation problem
Click Start, and type %AllUsersProfile%
The C:\ProgramData\TEMP, and folders your app can create in ProgramData, are
the places you are looking for.
Please use the Communities guidelines when posting.
http://www.microsoft.com/wn3/locales...help_en-us.htm
Use the "Ratings" feature. It helps the new users.
Mark L. Ferguson MS-MVP
https://mvp.support.microsoft.com/profile/Mark.Ferguson
"JohnNorth" <JohnNorth@xxxxxx> wrote in message
newsBE40226-10C6-4315-9EFD-8156BE94A70E@xxxxxx
Quote:
> Hi
> application?
Why is Hardware Assisted Virtualisation now mandatory? Virtual PC
Windows 7 virtualisation Virtual PC
[FR] Forums dédiés à la virtualisation Virtual Server
Program Files Virtualisation Vista account administration
"Program Files" directory problem - probably virtualisation issue Vista General
