crcdisk.sys problem
  1. #1
    Peter Afonin Guest
    crcdisk.sys problem
    Hello,
    I'm running 32 bit Vista Ultimate.
    Periodically I cannot boot my PC, it crashes with the blue screen. When I
    try to boot in safe mode, the boot stops displaying ../drivers/crcdisk.sys.
    Booting the "Last known good configuration" usually helps, but temporarily.
    There are many reports about this issue, but I couldn't find any good
    solution. I've tried chkdsk /r or /f, checked BIOS - didn't help.
    Is there a permanent solution to this problem? What's causing this? It seems
    that it started after the Windows update, but I'm not sure, and I don't know
    what exactly was installed. Also, this problem seems to be hardware related.
    I'm working with 3 Vista PCs, only one has this issue.
    I would appreciate your help.
    Thank you,
    Peter
  2. #2
    fatsteve Guest
    Re: crcdisk.sys problem
    Peter Afonin wrote:
    > Hello,
    It is normal for crcdisk.sys to be the last on the list of loading
    drivers, but as to why the boot into safe mode doesnt complete I cant help.
  3. #3
    Peter Afonin Guest
    Thanks. I wonder - is this a driver that is causing my computer to crash?
    Can I disable it somehow?
    "fatsteve" <internet@xxxxxx> wrote in message
    news:48e2c0c1$0$22566$5a62ac22@xxxxxx-qv1-newsreader-01.iinet.net.au...
    > Peter Afonin wrote:
    >> Hello,
    >> ../drivers/crcdisk.sys. Booting the "Last known good configuration"
    > help.
crcdisk.sys problem problems?
crcdisk.sys - problem loading Vista ess Drivers 22 11 Nov 2009
Solved Another crcdisk.sys error jhvegas General Discussion 5 04 Mar 2009
crcdisk.sys Kapp Vista General 2 15 Dec 2008
CRCDISK.sys? Arzal Drivers 0 06 Dec 2008
crcdisk.sys start up problem (with boot log) Jimmy Vista hardware & devices 2 13 Aug 2007
