Vista - auto play not opening usb storage
Old 10-03-2008   #1 (permalink)
maeve
Hi, I used to open usb storage devices by choosing an option from a menu
when I inserted my usb device. Now autoplay doesn't open these storage
devices and I have to open my computer and access the folders from there. I
have tried changing autoplay settings but still not working. Maybe there's
a box that I haven't ticked or something. My media center also won't open
videos but will play DVDs. Can someone help? Thanks
Old 10-04-2008   #2 (permalink)
Mark L. Ferguson
Re: auto play not opening usb storage
Usually that is caused by bad entries in the registry. Locations like (but
not exactly)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\DeviceClasses\{53f56307-b6bf-11d0-94f2-00a0c91efb8b}\##?#USBSTOR#Disk&Ven_OLYMPUS&Prod_FE210#X775&Rev_1.00#X61047734#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB\Vid_07b4&Pid_0109\X61047734
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USBSTOR\Disk&Ven_OLYMPUS&Prod_FE210/X775&Rev_1.00\X61047734
You can try exporting and deleting those type of entries, and see if it
helps. If not run the exported ?.REG files to restore the registry entries.
Please use the Communities guidelines when posting.
http://www.microsoft.com/wn3/locales...help_en-us.htm
Use the "Ratings" feature. It helps the new users.
Mark L. Ferguson MS-MVP
https://mvp.support.microsoft.com/profile/Mark.Ferguson
"maeve" <meathome@xxxxxx> wrote in message
news:2CE598C7-1755-434E-9D21-FF21B6F51116@xxxxxx
> I have tried changing autoplay settings but still not working. Maybe
> there's a box that I haven't ticked or something. My media center also
> won't open videos but will play DVDs. Can someone help? Thanks
How to avoid opening a recovery storage group using CDOEXM? VB Script
auto play Vista hardware & devices
auto play isn't there Vista General
Auto Play and Auto Run Vista Games
