Vista - How To Remove READYBOOST Cache, PLs Help Me!
Old 10-05-2008   #1 (permalink)
AhM3D
Im trying to use readyboost servies on my 2gb usb but i see this msg :
A cache exists on another device in the system. Please remove the cache
from that device before creating a cache on this device. ...
I formated my usb and i still see it , so how i delete that cache? :/
- Pls help me
- Ahm3dS...
AhM3D
Old 10-05-2008   #2 (permalink)
Paul Montgumdrop
Re: How To Remove READYBOOST Cache, PLs Help Me!
> - Pls help me
I am sure you'll find a solution out there somewhere.
<http://www.google.com/search?hl=en&q=A+cache+exists+on+another+device+in+the+system++Vista&btnG=Google+Search&aq=f&oq=>
Old 10-05-2008   #3 (permalink)
home premium vista (64bit)
do you have more then one flashdrive connected? cause i think what it's saying is
that the other device is already using the readyboost. and if so you can only use one
at a time (unless thay changed it in sp1).
scrooge
Old 10-05-2008   #4 (permalink)
AhM3D
@Paul
I tryed this but cant found anything ;-(
@scrooge
no i have just 1 usb :/
- Anyway thnx
AhM3D
ReadyBoost Cache Vista General
ReadyBoost cache keeps disappearing????? Vista General
ReadyBoost - Cache Exists Vista General
How can I delete ReadyBoost cache? Vista General
Readyboost cache not created Vista performance & maintenance
