Vista - Re: usb device removal
Old 10-06-2008   #1 (permalink)
Charlie42
"minimus" <spammergetthisemail@xxxxxx> wrote:
Quote:
> When you plug a usb device, you can unplug it by pressing the
> icon on the bar and select the device to be jected.
> Ok this is easy but I am seeking even an easirer short cut.
> What I want my vista do is that when I plug usb devices, make an
> icon for each of them on the bar such that if i click on them I can
> unplug it directly.
> So, i dont want to press an icon and then choose the usb device
> tobe ejected, but I want a direct icon that orders the respective
> usb device to be ejected.
> Is there a way?
> a gadget, a program or whatsoever that makes it easieer to
> manage usb devices?
You can use Explorer. Right-click the device you want to eject, then pick
"Eject" from the context menu.
Charlie42
Old 10-06-2008   #2 (permalink)
Vista Ultimate x64
> unplug it directly.
> Is there a way?
> manage usb devices?
or even easier
left click on a removable icon on ur system tray and choose wich one you gonna eject
ie7 removal Vista General
Device driver removal process Drivers
Re: usb device removal Vista General
Tag Removal Vista music pictures video
What triggers 1394 "Device Removal" ? Vista hardware & devices
