Vista - Re: usb device removal
Old 10-06-2008   #1 (permalink)
Zaphod Beeblebrox
"minimus" <spammergetthisemail@xxxxxx> wrote in message
news:gcb26v$aaa$1@xxxxxx
Quote:
> People,
> When you plug a usb device, you can unplug it by pressing the icon on
> the bar and select the device to be jected.
> Ok this is easy but I am seeking even an easirer short cut.
> What I want my vista do is that when I plug usb devices, make an icon
> for each of them on the bar such that if i click on them I can unplug
> it directly.
> So, i dont want to press an icon and then choose the usb device tobe
> ejected, but I want a direct icon that orders the respective usb
> device to be ejected.
> Is there a way?
> a gadget, a program or whatsoever that makes it easieer to manage usb
> devices?
> I use ultimate
See if this might help, it appears to be capable of what you are asking
but I haven't tried it.
http://www.howtogeek.com/howto/windo...fic-usb-drive/
Zaphod
No matter where you go, there you are!
Old 10-07-2008   #2 (permalink)
minimus
this is it. thanks a lot
ie7 removal Vista General
Device driver removal process Drivers
Re: usb device removal Vista General
Tag Removal Vista music pictures video
What triggers 1394 "Device Removal" ? Vista hardware & devices
