Vista - Need help with folder options please
Old 10-06-2008   #1 (permalink)
beestar
Hi all,
I was wondering if anyone could help, I'm using Vista and quite
familiar with it already but it is giving me some trouble. It may be
just machine but maybe someone has experienced same problem and can help
me.
I am having difficulties changing folder options? it sounds strange but
its true. For example, I want to view file extentions, but when i got
Tools, Folder Options, View and Advance settings, i UNCHECK the box for
Hide Extention files, but for some reasons nothing changes?
Can anyone help? is there some settings i've got that wont allow me to
change settings??
thanks
beestar
beestar's Profile: http://forums.techarena.in/members/beestar.htm
View this thread: http://forums.techarena.in/vista-help/1050406.htm
Old 10-06-2008   #2 (permalink)
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
Re: Need help with folder options please
Quote  Quote: Originally Posted by beestar View Post
Hi all,
me.
change settings??
thanks
beestar
Hi Beestar,
It may be that you need to look at the settings for Remember each folders view settings, and Restore previous folder view at logon. You also need to Apply and OK any changes.
You may also like to see this tutorial
Folder Options
Hope it helps
SIW2
Old 10-06-2008   #3 (permalink)
beestar
thanks for your response SIW2, I had done what you suggested, checked
both Remember each folder settings and Restore, both they stay checked
or unchecked when I do check and uncheck them BUT ONLY Hide extention
known files dont change? this is strange and is really bugging me. I've
followed a tutorial how to delete a NeverShowExt value in the registry
and this has no effect on it? so so strange..
beestar
Folder Options Tutorials
Folder options Vista General
Folder Options Vista General
How to set folder options to apply one to one folder but not the other? Vista file management
