Vista - Problem upgrading to Vista on Sony Vaio laptop
Old 10-06-2008   #1 (permalink)
its_my_dime
My laptop came with XP but with a Vista upgrade disk. I finally decided to
do the upgrade and am having real problems.
While the computer is light on processing power and memory (1 gig), it is
supposed to run Vista. However, I find that it has stalled to a crawl
because my processor is always running at 100% while the memory is only in
the 60% range. However, in SAFE MODE, the processor only runs at 20%. So I
assume something is being loaded that is killing the processor. I also
found that, somewhere in the normal bootup process, the processor usage
jumpted from 60% to 100%.
How do I find out what the problem is. Does Vista have diagnostics that
shows how much processor power each process uses? Or is there a way I can
load one file at a time while watching the processor meter to see where it
jumps?
If I can't fix this issue, I'll plan to go back to XP.
Thank you.
Old 10-06-2008   #2 (permalink)
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
Re: Problem upgrading to Vista on Sony Vaio laptop
Quote  Quote: Originally Posted by its_my_dime View Post
jumps?
Thank you.
You might have a look under the processes tab in Task Manager and see if that reveals anything
Task Manager - Open and Close Applications and Processes
Hope it helps
SIW2
Old 10-06-2008   #3 (permalink)
its_my_dime
"SIW2" <guest@xxxxxx-email.com> wrote in message
news:fed08dfd2dcd74cfe4c5616edff42b5b@xxxxxx-gateway.com...
Quote:
> its_my_dime;854447 Wrote:
>> to
>> is
>> in
>> So I
>> that
>> can
>> it
>> jumps?
>> Thank you.
> Hi,
> Hope it helps
> SIW2
It looks like the problem relates to something called zerocfgsvc
application, an Intel that leads to a file called ZCfgSvc.exe.
I don't know if this is something Vista needs, but I've disabled it and the
CPU usage has dropped from 100% to 20%!!
Thank you.
Old 10-07-2008   #4 (permalink)
>> to
>> is
>> in
>> So I
>> that
>> can
>> it
>> jumps?
>> Thank you.
> Hi,
> Hope it helps
> SIW2
Thank you.
Hi ,
That has known compatibility issues with Vista. Part of Intel utilities for some of their wireless network cards. Suggest you check for new drivers with your laptop manufacturer and Intel .
Download Software, Drivers and Utilities
Glad it's running better now
SIW2
UPGRADING SONY VAIO VGN TXN15P FROM XP PROFESSIONAL TO VISTA BUSINESS. Vista General
Few Issues: [Sony VAIO Laptop] General Discussion
UPGRADED SONY VAIO LAPTOP TO VISTA ULTIMATE; HAVE JUMPING CURSOR Vista General
Cannot run windows update on sony vaio laptop running vista business Vista General
audio problem with my sony vaio laptop and x64 problem Vista hardware & devices
