Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
br> br> |
| | Thread Tools | Display Modes |
| Junior Member Rep Power: 1 ![]() | Sleep and its power consuming Because of the time-consuming booting procedure,I usually use Sleep button to turn off computer.However, this utility still consumes electricity so I fear of my energy bill.So anyone know exact how much electricity that sleep state uses.And if the power was shut suddenly,how can I protect my work and data from losing.?Thanks. |
| Vista Expert - MVP ![]() Rep Power: 22 ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Re: Sleep and its power consuming You might want to take a look at this web page: Set up S3 sleep state in Vista for significant power savings And as far as losing your work if there is a power outage, it depends upon whether you use normal sleep or Vista's new "hybrid sleep": http://windowsitpro.com/article/arti...eep-modes.html Last edited by LeeTutor; 10-07-2008 at 09:46 AM. Reason: insert missing link |
| | #3 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Sleep and its power consuming "daretofail" <guest@xxxxxx-email.com> wrote in message news:c3ff78efe622a81eb3d2ffdf5e3e4d13@xxxxxx-gateway.com...
are off. Only the RAM remains powered on and sometimes the keyboard or mouse if its setup like that. Typically a computer in S3 state will only draw 2 or 3 watts. Easily less than 1 percent the power draw of a machine when its on. In the UK we get charged about 12p p/kWh. So to run a machine in S3 for the whole year 24/7 would cost about £2, about $4.
hibernate) when when it goes to sleep. So that if the machine does lose power it will reload it all from the hard disk when the machine starts, it'll take a bit longer to boot this way, but the all the data should be intact. You can check to make sure hybrid sleep is enabled by going into Power Options -> Edit plan settings, and then Change advanced power settings. Then under sleep there should be an option called 'Allow hybrid sleep' as long as that is set to yes, all the data will be saved to the disk as well as being left in RAM. -- Paul Smith, Yeovil, UK. Microsoft MVP Windows Shell/User. http://www.dasmirnov.net/blog/ http://www.windowsresource.net/ *Remove nospam. to reply by e-mail* | ||||||||||||||||||||||||
My System Specs![]() | |||||||||||||||||||||||||
| Junior Member Rep Power: 1 ![]() | Re: Sleep and its power consuming thank for your two posting.The advice works very well.And I think Paul Smith is a professional in PC even he is a guest. |
| | #5 (permalink) | ||||||||||||
| Guest | Re: Sleep and its power consuming daretofail wrote:
question exactly. Here's a bunch on Ebay: http://shop.ebay.com/?_from=R40&_trk...All-Categories | ||||||||||||
| | #6 (permalink) |
| Guest | Re: Sleep and its power consuming I've measured mine and it's 6W. Interestingly, it's also 6W when it's switched off, so there is no advantage in switching off for me, and I always use Vista's sleep mode. Remember, modern PCs have a "soft off" which keeps the PSU and the odd bit of the mobo powered. On mine the only way to get it down to zero is to switch it off at the wall. SteveT |
| | #7 (permalink) |
| Member ![]() Rep Power: 11 ![]() ![]() ![]() | Re: Sleep and its power consuming [quote=Paul Smith;854812]"daretofail" Typically a computer in S3 state will only draw 2 or 3 watts. Easily less than 1 percent the power draw of a machine when its on. In the UK we get charged about 12p p/kWh. So to run a machine in S3 for the whole year 24/7 would cost about £2, about $4. [quote] Where do you get < 1 percent? Your computer actually uses like 200-300 Watts? |
| Display Modes | |
| sleep and power | stev1987 | Vista installation & setup | 1 | 02-23-2008 08:46 AM |
| Power Setting for 'sleep-like' mode | Bonnie. | Vista networking & sharing | 2 | 08-09-2007 10:18 PM |
| Re: no sleep recovery after power down | John Hanley | Vista performance & maintenance | 3 | 06-28-2007 04:18 AM |
| no sleep recovery after power down | knight-gkla | Vista performance & maintenance | 5 | 06-24-2007 12:48 PM |
| Power and Sleep Settings | chick | Vista General | 1 | 04-21-2007 10:04 PM |
| Complimentary Industry Resources Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today! |
