Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
br> br> |
| | Thread Tools | Display Modes |
| Guest | Can't use both wired and wireless networking at same time I have a new laptop with Vista Home Premium and I am using the wireless connection to reach a router to connect to the Internet. When I attach a cable for my local network, the connection to the Internet is broken. I am still connected to the wireless router, but the Internet connection is lost. If I disconnect the wired LAN connection the Internet connection returns after a while. I had been trying to share the Internet connection, but now I just want to be able to access both from this machine. |
| | #2 (permalink) | ||||||||||||
| Guest | Re: Can't use both wired and wireless networking at same time "nemo" <gnuarm@xxxxxx> wrote in message news:6de423ce-b20b-47ae-b03a-5d6c8b355a0e@xxxxxx
your local network hub. That way you have internet connection thru the wire AND you can see your local network when running wireless. This is the way I have always done it here. | ||||||||||||
My System Specs![]() | |||||||||||||
| | #3 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Can't use both wired and wireless networking at same time On Oct 7, 10:39*am, "Bob Campbell" <b...@xxxxxx> wrote:
of the wireless connection! PCs can and have used more than one network interface for many years. There is something goofy about the configuration under Vista. I have done this before under Win2k. I have even shared a modem over a network under Win2k. | ||||||||||||||||||||||||
My System Specs![]() | |||||||||||||||||||||||||
| | #4 (permalink) | ||||||||||||
| Guest | Re: Can't use both wired and wireless networking at same time On Tue, 7 Oct 2008 10:17:30 -0700 (PDT), nemo <gnuarm@xxxxxx> wrote:
Not a direct answer... but Vista definitely has some issues in this area. Myself and associates have found it exceedingly difficult even to switch from wireless to wired; or in the case of wired, to disconnect the cable without Vista going into a hung state. Generally you have to disable and enable the cards before making any changes or it rarely hooks up correctly. One associate finds that he can't even change wireless networks without disabling/enabling the network interface. Some folks have managed to pull off the switch by issuing an ipconfig/renew. On other systems, nothing short of a reboot allows it to happen. Perhaps the reboot with both connections hooked up or disable wireless -connect wired - enable wireless scenario would work. | ||||||||||||
| | #5 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Can't use both wired and wireless networking at same time On Oct 7, 7:31*pm, "Bob Campbell" <b...@xxxxxx> wrote:
That is right, you don't understand. The Internet connection is in one place and the wired network is in another. To do what you are suggesting would require me to put everything in one place. Not much point to using wireless if I have to run a cable just to put the wired connections on the Internet. That is the part you aren't grasping. The wired network is not near the Internet connection, so I can't just put them all on the same router. | ||||||||||||||||||||||||
| | #6 (permalink) |
| Ex Bar Steward ![]() Join Date: Jul 2008 Vista Home Premium x86 SP1 / Win 7 6801 x86 / Ubuntu 8.04 x64 / XP Home SP3 Newport, South Wales, UK Rep Power: 41 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Re: Can't use both wired and wireless networking at same time firstly are the local and internet NIC's on the same or different subnets? are you attempting to use the laptop as a wireless access point for the rest of the local network? if you can post back the results of an ipconfig /all that may help diagnose a solution |
| | #7 (permalink) | ||||||||||||
| Guest | Re: Can't use both wired and wireless networking at same time "nemo" <gnuarm@xxxxxx> wrote in message news:cb54d150-50b5-4458-a19b-82a1dce2a9ed@xxxxxx
Ah, OK. Well, all I can say is I would never do it that way. As you have discovered, there is not much point to having a wireless network if your wired network can't see it. My cable modem/router/wired network/hub/desktops/servers are all in the same room. My desktops/servers use wired, laptops can use wireless and wired. All can see each other. If I was in your situation, I would either call the cable company and get another cable drop, or I would be running CAT6 cable along baseboards/under carpet/thru walls/whatever I had to do, in order to get my wired and wireless networks connected. As you add more computers/devices/who-knows-what-is-coming-in-the-future, you will find it very convenient to have every device talking to every other device, wired or wireless As for your original problem, I don't see that here. If I unplug my router from my hub, then plug my laptop into the hub, my internet connection remains thru the wireless, and I can see the local wired network. So both networks are definitely working. The wireless connection goes off for a few seconds (gets a yellow icon in the system tray), but it comes back on after Vista figures out the networking. In the Network and Sharing Center in Control Panel, the wireless connection shows "Local and Internet", the wired connection shows "Local only". I realize none of the above is much help, but it shows it CAN be done. You must have something configured wrong. In the TCP/IPv4 properties for your wired connection, there should be no Gateway address or DNS Server address. You need only IP Address and Subnet Mask. Are you using Static addresses, or is one of your machines handing out address thru DHCP? | ||||||||||||
| | #8 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Can't use both wired and wireless networking at same time Bob, I have configured many systems with multiple nics, wireless and wire all connected to different networks doing various stuff. We live in a complex world and many people have different needs even for strange configurations like this. All this with XP though... Indeed many people are having trouble with doing this vista, many people complain to me all the time, but im not sure yet if it's the drivers or Vista itself... "Bob Campbell" <bob@xxxxxx> wrote in message news:7pKdnRR5pN2LLXHVnZ2dnUVZ_uOdnZ2d@xxxxxx
| | #9 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | Re: Can't use both wired and wireless networking at same time to give you an example of this, on one machine you get the internet from a cable, and you "share" it from the wireless network card in ad-hoc mode.. this is useful if you don't have a router, it's a dirty solution but sometimes people need this as a temporary solution and don't have a router at hand "the granter of sina" <granter@xxxxxx> wrote in message news:48ecf8a4@xxxxxx-privat.org...
My System Specs![]() | |||||||||||||||||||||||||||||||||||||
| | #10 (permalink) |
| Member ![]() Rep Power: 4 ![]() ![]() | Re: Can't use both wired and wireless networking at same time i do what ur trying to achieve all day everyday on my Vista laptop, so let me just tell you its not a fault of the OS. Heres a quick rundown. I have the internet cable modem connected to the wired network, or usb, with auto configured IP which successfully comes from the Network Provider. I then have manual configured IP address's for the wireless network, configuring the box sharing the connection as 192.168.0.1 and the other boxes with gateway set to 192.168.0.1 Then on the shared connection box i configure to share the connection on the wired adapter with the wireless. And it works all the time, everytime, 100% reliable. XP used to be flaky on the wireless connection to my PDA especially, but Vista is awesome. |
| Display Modes | |
| switching from wireless to wired networking does not work | dna86 | Vista networking & sharing | 3 | 12-14-2007 09:41 AM |
| Wireless/Wired networking? | thecadillacboy | Vista networking & sharing | 7 | 11-21-2007 02:33 PM |
| Networking wireless and wired without router | bwchaos | Vista networking & sharing | 6 | 10-03-2007 05:37 AM |
| Xbox 360 and Vista MC networking wired/wireless | JonkyB | Vista networking & sharing | 0 | 06-15-2007 10:54 PM |
| Wireless and Wired Networking help | Jeff Banks | Vista networking & sharing | 2 | 09-18-2006 10:24 PM |
| Complimentary Industry Resources Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today! |
