| | printer problem to domain's printer Hi All, I have a guest's Vista laptop that is not part of the domain. I've connected it to one of our domain printers, while connecting vista asked for username and password, so i entered one domain username and password, and tick the remember my password. It worked fine. But if user shutdown the laptop and turned it back on, he could not print anymore. What I did was deleted the printer and re-connected again. is there any other way to make vista remember the domain username/password so i don't need to delete/reconnect everytime he start using the laptop? any help would be very much appreciated. TIA. |
| | Re: printer problem to domain's printer andifebr@xxxxxx wrote: Quote: > Hi All, > I have a guest's Vista laptop that is not part of the domain. > I've connected it to one of our domain printers, while connecting > vista asked for username and password, so i entered one domain > username and password, and tick the remember my password. It worked > fine. > > But if user shutdown the laptop and turned it back on, he could not > print anymore. > What I did was deleted the printer and re-connected again. is there > any other way to make vista remember the domain username/password so i > don't need to delete/reconnect everytime he start using the laptop? > any help would be very much appreciated. it is one of the Home editions. If this is the case, then the behavior is as expected since Home versions cannot cache passwords. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ |
| XP desktop printer networked to VISTA laptop - adding printer error | Vista print fax & scan | |||
| Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) | Vista General | |||
| Vista wont put my printer in the printer folder in control panel | General Discussion | |||
| can not connect to a network printer brother laser printer | Vista networking & sharing | |||
| Lexmark Printer / Error problem communicating with printer | Vista print fax & scan | |||
