Vista - power consumption?
Old 10-11-2008   #1 (permalink)
jakein2008
power consumption?
I have a desktop computer which run Vista , when it is in the sleep ,does it
consume any electronic power or the power consumption can be ignored?
Thanks.
Old 10-11-2008   #2 (permalink)
philo
Re: power consumption?
"jakein2008" <jakein2008@xxxxxx> wrote in message
news:75165D76-9A16-4129-B5EF-78170D037132@xxxxxx
it
> Thanks.
It still draws power
but not much...
Maybe 25 watts or so
Old 10-11-2008   #3 (permalink)
Steve Thackery
Mine draws 6W in sleep, which is the same as when it is switched off. Only
by unplugging it does it go to zero.
SteveT
Old 10-11-2008   #4 (permalink)
Ian D
>it
> Thanks.
In sleep mode the CPU, drives, and video are off, but the motherboard
clock is still running to keep the memory refreshed. It still consumes
power, but not much more than powered off, plugged in. When the system
is powered off the mouse, keyboard, or LAN could still be powered, to
perform wake-up functions, depending on their BIOS settings.
Old 10-11-2008   #5 (permalink)
NotEvenMe
unless you pull the plug or turn off the power strip, the machine will draw
between 25-40W in sleep/hibernate mode or 6-10W when 'off'.
>it
> Thanks.
Old 10-12-2008   #6 (permalink)
the granter of sina
Pphooyyyyeeeeeee !!!!!!!!
Hibernate is like OFF you imbecile, windows just writes the data from the
ram to the disk and turns off!
you can unplug it for a week, then plug it back in, turn it on, and it will
restore the state from hibernation!
Gesh!
"NotEvenMe" <cargod01@xxxxxx> wrote in message
news:O#llFc$KJHA.5904@xxxxxx
> draw between 25-40W in sleep/hibernate mode or 6-10W when 'off'.
>>it
>> Thanks.
Problem with media center and power consumption Media Center
x1550 power consumption Graphic cards
CPU consumption Vista performance & maintenance
Vista Sleep Mode Power Consumption? Vista hardware & devices
Power consumption in S3 standby mode? Vista General
