| | weird problem Hi, I use ultimate and have a weird problem. sometimes my mouse moves slow. I disconnet my wireless int connection then it becomes its normal condition. Or it corrects itself after a while. I dont have any idea what happens but it seems that it is related to the wireless connection. my mouse is logitech wireless mouse. my cofig is 2gb ram 512 mb ram 2.4 ghz core duo |
| | Re: weird problem its not the mouse that is the problem... download this free app called process explorer from Microsoft, http://technet.microsoft.com/en-us/s.../bb896653.aspx and when you see this behavior take a look at what is hogging up your CPU. My guess is that you will see too many interupts and DPC's If this is the case then something is wrong with the wireless driver, I may have a solution for you, but first take a look with process explorer "minimus" <spammergetthisemail@xxxxxx> wrote in message news:gctpom$nbf$1@xxxxxx Quote: > > Hi, > > I use ultimate and have a weird problem. > > sometimes my mouse moves slow. > > I disconnet my wireless int connection then it becomes its normal > condition. > > Or it corrects itself after a while. > > I dont have any idea what happens but it seems that it is related to the > wireless connection. > > my mouse is logitech wireless mouse. > > my cofig is 2gb ram 512 mb ram 2.4 ghz core duo > > > |
| | Re: weird problem Thank you for your concern. Before installing the program, is not possible to see the cpu usage or others via the task manager? If not, then I will install the program and inform you back |
| Weird - Very weird annoying problem | General Discussion | |||
| Weird ICS problem | Vista networking & sharing | |||
| weird problem | Vista mail | |||
| weird problem | Vista General | |||
| weird problem | Vista performance & maintenance | |||
