Vista Forums Home Join Vista Forums Tech Publications Windows 7 Forum Vista Tutorials Webcasts Tags
Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
The Application Failed to Initialize properly (0xc0000022) Click Ok to Terminate the
Update your Vista Drivers
Thread Tools Display Modes
Old 10-14-2008   #1 (permalink)
Junior Member
Vista 64
wadeb_21 is on a distinguished road
  wadeb_21 is offline
For some reason I am getting this error code (Explorer.exe The Application Failed to Initialize properly (0xc0000022). Click Ok to Terminate the Application) whenever I try to log into my computer. I put in my password and then this message comes up and nothing happens it wont go to my desktop or anything. I then restarted and logged into my machine through safe mode and everything works. I tried to run a windows update to see if I was missing an update or something but in Safe Mode it will not let me run Windows updates. I also went to add and remove programs and tried to uninstall the most recent application I installed to see if that was the problem but once again I can not uninstall anything in safe. If someone could help me out with this problem I would really appreciate it thanks.
Old 10-14-2008   #2 (permalink)
Junior Member
Vista 64
  wadeb_21 is offline
Re: The Application Failed to Initialize properly (0xc0000022) Click Ok to Terminate
Does anyone have any info, that can help me? I would really appreciate it?
Old 4 Weeks Ago   #3 (permalink)
Flavius's Avatar
Senior Member
Vista Ultimate x86
Flavius has a spectacular aura aboutFlavius has a spectacular aura aboutFlavius has a spectacular aura about
  Flavius is offline
Try this:
Start>>Run>>cmd.exe and type
CACLS %systemroot%\System32\*.dll /E /G BUILTIN\Users:R
CACLS %systemroot%\System32\*.ocx /E /G BUILTIN\Users:R
and restart
Old 4 Weeks Ago   #4 (permalink)
Mr. Arnold
Guest
Re: The Application Failed to Initialize properly (0xc0000022) ClickOk to Terminate the
http://support.microsoft.com/kb/929833
Old 4 Weeks Ago   #5 (permalink)
Junior Member
Vista 64
  wadeb_21 is offline
Quote:
Flavius
View Post
Try this:
and restart
Thanks for getting back to me I really appreciate it. I just tried this and it tells me access denied. Do you know why it would say that?
Old 4 Weeks Ago   #6 (permalink)
Junior Member
Vista 64
  wadeb_21 is offline
Quote:
Mr. Arnold
View Post
Some Windows Vista functions may not work, or Windows Vista may stop responding
So I followed the instructions from the link you posted did the scan and it did find errors but couldn't fix them so I opened up the log it produced from the scan but I have no idea how to tell what files it didn't repair. Do you know how to tell? Or no of another way to fix this problem?
Old 4 Weeks Ago   #7 (permalink)
Mr. Arnold
Guest
wadeb_21 wrote:
Quote:
> Mr. Arnold;861627 Wrote:
Quote:
>> wadeb_21 wrote:> > >
>>> put
>>> my
>>> windows
>>> Mode
>>> installed
>>> would
>> 'Some Windows Vista functions may not work, or Windows Vista may stop
>> responding' (http://support.microsoft.com/kb/929833)
> this problem?
The log file is a text file is it not? So open it with Notepad or
something and copy/past the context in a post.
I am not saying I can help you, but maybe, or someone else can help you.
Old 4 Weeks Ago   #8 (permalink)
Flavius's Avatar
Senior Member
Vista Ultimate x86
  Flavius is offline
Did you all in normal mode or safe mode?If you did in normal mode it was fails because you have UAC turned on - you have to run cmd.exe with administrative previlliges (right click on it>>run as administrator) and then repeat my commands or repeat all from post 3 in safe mode.I thought you can't log in normal mode
Old 4 Weeks Ago   #9 (permalink)
Junior Member
Vista 64
  wadeb_21 is offline
Quote:
Flavius
View Post
I just tried both in Safe mode the first code worked fine then it did the second one and I'm still getting access denied, I then restarted to see what would happen and I"m still having the same problem. Man this is getting fustrating, I don't understand what caused this problem. Do you have any other suggestions?
Old 4 Weeks Ago   #10 (permalink)
Flavius's Avatar
Senior Member
Vista Ultimate x86
  Flavius is offline
I think you have some kind of problems with permissions.Try any which Arnold gave you: i.e
Try this command in cmd.exe
takeown /f C:\windows\system32\jscript.dll
icacls C:\windows\system32\jscript.dll /grant administrators:F
if these commands also return "access denied" you will have really big trouble...
Display Modes
Application failed to initialize properly (0xc0000005) T L Hill Vista installation & setup 4 02-07-2008 04:16 PM
Application failed to initialize properly (0xc0000142) Roger Van Loon Vista General 3 01-11-2008 06:10 PM
AVCapture.exe- The application failed to initialize properly Charlie1234 Vista installation & setup 1 07-04-2007 03:03 PM
AVCapture.exe The application failed to initialize properly (0xc00 Charlie1234 Vista installation & setup 0 07-04-2007 02:52 PM
Atbroker.exe "application failed to initialize properly" on remote desktop to vista markm75 Vista General 1 02-05-2007 05:51 PM
Complimentary Industry Resources
Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today!
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
