Vista - Excel crashes on exit - OLEAUT32.DLL problem
Old 10-17-2008   #1 (permalink)
Windows Vista Home Premium V6.0 32 bit
Good day,
When trying to exit from Excel (2003 or 2007) by pressing Excel's X button program crashes (stop working). Meantime if firstly close the opened file and after that close the Excel itself it closes by normal way.
The following information for the error appear:
Problem signature:
Problem Event Name: APPCRASH
Application Name: EXCEL.EXE
Application Version: 11.0.8231.0
Application Timestamp: 48934d57
Fault Module Name: OLEAUT32.dll
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a74f
Exception Code: c0000005
Exception Offset: 00004580
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
LCID: 1033
Brand: Office11Crash
skulcid: 1033
Read our privacy statement:
Microsoft Online Crash Analysis
Please advise any solution or where to find good OLEAUT32.DLL
This problem is very old in my computer hence I can not use the Windows restore function.
Best regards.
Old 10-17-2008   #2 (permalink)
Excer crashes on exit - OLEAUT32.DLL problem
When closing Excel (2003 or 2007) it crashes and stop working. Meantime if firstly close the opened files and after that close the Excel itself it exits normally.
The following error description appears when crashing:
Problem signature:
Locale ID: 1033
LCID: 1033
skulcid: 1033
Please advise solution or where to find good OLEAUT32.DLL
This problem is very old in my laptop hence Windows restore is not applicable.
Best regards
Old 02-20-2009   #3 (permalink)
Vista32 Business
Re: Excer crashes on exit - OLEAUT32.DLL problem
Try disabling your Excel add-ins and test. If this doesn't work, try changing
the value of LoadBehavior from 3 to 0 under this registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Excel\Addins
Salvador Manaois III
MCSE MCSA CEH MCITP | Enterprise/Server Admin
Bytes & Badz : http://badzmanaois.blogspot.com
Vista 64-bit Crashes Excel Vista General
Word 2007 Crashes after exit Microsoft Office
EXCEL CRASHES Vista General
Excel 97 crashes in Vista Vista General
Outlook 2000 & RC1: Startup appears every time and crashes on exit Vista mail
