| | Help with Installing Nvidia card I bought Nvidia Geforce Card for a dual boot HP Pavillion running XP and RC1. I need help in installing the card. On which of the partitions do I install it first. How do I avoid problem of blank screen after installing the card. Obi |
| | Re: Help with Installing Nvidia card Each installation is separate and in no particular order. Btw, I assume by installation you mean the drivers. You shouldn't get a bsod b/c the default drivers will work initially. "Obialor" <Obialor@discussions.microsoft.com> wrote in message news:34A31BF2-C6F5-416A-A96C-F7FB191AE846@microsoft.com... >I bought Nvidia Geforce Card for a dual boot HP Pavillion running XP and >RC1. > I need help in installing the card. On which of the partitions do I > install > it first. How do I avoid problem of blank screen after installing the > card. > Obi |
| | Re: Help with Installing Nvidia card You may need to boot into VGA mode and reset the refresh rate or resolution "Obialor" <Obialor@discussions.microsoft.com> wrote in message news:34A31BF2-C6F5-416A-A96C-F7FB191AE846@microsoft.com... >I bought Nvidia Geforce Card for a dual boot HP Pavillion running XP and >RC1. > I need help in installing the card. On which of the partitions do I > install > it first. How do I avoid problem of blank screen after installing the > card. > Obi |
| Going from NVidia to AMD card.... | Graphic cards | |||
| Installing a PCMCIA Card Drive in desktop to use PC5740 card in | Vista networking & sharing | |||
| NVIDIA GRAPHICS CARD USING RAM | Vista hardware & devices | |||
| Installing Nvidia Geforce Card | Vista hardware & devices | |||
| nVidia 6600 card | Vista hardware & devices | |||
