| | Shutdown & restart problems I am having the same problem with my laptop (Toshiba Satellite M100), I have Windows Vista Ultimate (no SP1 yet)... Have you found the problem? I've looked everywhere and no luck... |
| Home premium 32 bit, SP1 | Re: Shutdown & restart problems |
| | Re: Shutdown & restart problems Partager 2000 wrote: Quote: > I am having the same problem with my laptop (Toshiba Satellite M100), I > have Windows Vista Ultimate (no SP1 yet)... Have you found the problem? > I've looked everywhere and no luck... Usenet posts. Most of us use real newsreaders to access Usenet so don't see the post to which you're referring. Please post back with a full description of your problem per the "How to Post" section below. You might also want to consider using a real newsreader to access newsgroups. It is very easy to set up and more efficient than what you're doing. Information below. ***** Since you are using a web interface, you may not realize that this is really a newsgroup. You will get far more out of this resource if you learn to use a newsreader. There are many good newsreaders for Windows, but you can use Outlook Express (XP) or Windows Mail (Vista) since you already have it. Here are some links to information about newsgroups: About Usenet: http://en.wikipedia.org/wiki/Usenet http://www.faqs.org/faqs/ - Usenet FAQs from the Internet FAQ Archives http://www.usenetmonster.com/infocenter/ http://www.elephantboycomputers.com/page2.html#Usenet - a brief explanation of newsgroups Outlook Express/Windows Mail as Newsreader: http://michaelstevenstech.com/outloo...snewreader.htm http://rickrogers.org/setupoe.htm http://vistasupport.mvps.org/accessi...ndows_mail.htm How to Post: http://www.elephantboycomputers.com/page2.html#Usenet http://support.microsoft.com/default.aspx/kb/555375 - How to Ask a Question http://users.tpg.com.au/bzyhjr/liszt.htm - How Not to Get Technical Help on Usenet http://www.catb.org/~esr/faqs/smart-questions.html http://aumha.org/nntp.htm - list of MS newsgroups microsoft.public.test.here - MS group to test if your newsreader is working properly http://www3.telus.net/dandemar/munad.htm - how to munge email address http://en.wikipedia.org/wiki/Crossposting - crossposting http://www.blakjak.demon.co.uk/mul_crss.htm - multiposting ***** Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ |
| Shutdown & restart problems | Vista General | |||
| Wish to confirm shutdown/restart | Vista installation & setup | |||
| Slow Shutdown / Restart | Vista General | |||
| Shutdown/Restart looks unfinished: | Vista General | |||
| No OPtion for shutdown or restart | Vista General | |||
