| | processor power management features have been disabled due to a known firmware error EVENT ID 6 <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> - <System> <Provider Name="Microsoft-Windows-Kernel-Processor-Power" Guid="{0f67e49f-fe51-4e9f-b490-6f2948cc6027}" /> <EventID>6</EventID> <Version>0</Version> <Level>2</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x8000000000000000</Keywords> <TimeCreated SystemTime="2008-10-27T17:54:07.718Z" /> <EventRecordID>27167</EventRecordID> <Correlation /> <Execution ProcessID="4" ThreadID="48" /> <Channel>System</Channel> <Computer>JIMBOXP-PC</Computer> <Security UserID="S-1-5-18" /> </System> <EventData /> </Event> This is the copy of the system error log, it happens every time I boot up and there are loads of postings on the Technet web page but NO answers or fixes and a deafening silence from Microsoft. It seems to be a common fault with SP1 and before anyone says it, there isn't the option to uninstall SP1 in my programs folder or updates folder. If you don't have your PC set to automatically restart after errors then a blue screen follows at some point. System is pentium 4 dual core 3 ghz 2gb ram 32 bit and vista ultimate , all drivers and updates are up to date. If anyone from Redmond reads this please respond with only sensible answers and not the one I got recently about another problem with Vista, quote " this is beyond the scope of the company please clean install your system and see if that resolves the issue". It did but now this event keeps happening. |
| | Re: processor power management features have been disabled due to a known firmware error EVENT ID 6 Usually you have to tick the box that says...show updates. From the verbage of the error, it sounds like the hardware maker needs to release a newer version of the firmware, or MS needs to get their act together and quit breaking things. "JAMES" <wood.cottage@xxxxxx> wrote in message news:6902ED18-411B-4538-9CE7-5474CD4F1D4A@xxxxxx Quote: > <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> > - <System> > <Provider Name="Microsoft-Windows-Kernel-Processor-Power" > Guid="{0f67e49f-fe51-4e9f-b490-6f2948cc6027}" /> > <EventID>6</EventID> > <Version>0</Version> > <Level>2</Level> > <Task>0</Task> > <Opcode>0</Opcode> > <Keywords>0x8000000000000000</Keywords> > <TimeCreated SystemTime="2008-10-27T17:54:07.718Z" /> > <EventRecordID>27167</EventRecordID> > <Correlation /> > <Execution ProcessID="4" ThreadID="48" /> > <Channel>System</Channel> > <Computer>JIMBOXP-PC</Computer> > <Security UserID="S-1-5-18" /> > </System> > <EventData /> > </Event> > This is the copy of the system error log, it happens every time I boot up > and there are loads of postings on the Technet web page but NO answers or > fixes and a deafening silence from Microsoft. It seems to be a common > fault with SP1 and before anyone says it, there isn't the option to > uninstall SP1 in my programs folder or updates folder. > > If you don't have your PC set to automatically restart after errors then a > blue screen follows at some point. > > System is pentium 4 dual core 3 ghz 2gb ram 32 bit and vista ultimate , > all drivers and updates are up to date. > > If anyone from Redmond reads this please respond with only sensible > answers and not the one I got recently about another problem with Vista, > quote " this is beyond the scope of the company please clean install your > system and see if that resolves the issue". It did but now this event > keeps happening. |
| Processor Power Management | Vista performance & maintenance | |||
| Power Management/Power Options in Vista | Vista General | |||
| P4 HT computer/ Event: 6, Source: Kernel-Processor-Power, Level: E | Vista hardware & devices | |||
| What is minimum and maximum processor state in power management | Vista performance & maintenance | |||
| Power Management Issues (Underclocked Processor) | Vista performance & maintenance | |||
