Vista - Wrong screen vertical and horizontal scale
Old 10-29-2008   #1 (permalink)
_CragTheCode
After I started with Vista, i found this problem in my Autodesk Autocad (a
engineering drafting software):
Even i draw a square, the horizontal line appear long than vertical line on
screen.
I dont think i can do something within Autocad, so im thinking for in
Windows setting.
Any clue?
Old 10-30-2008   #2 (permalink)
Mark L. Ferguson
Re: Wrong screen vertical and horizontal scale
You might try changing the ICON font in the Advanced settings of
Personalizations/Window color.../Open classic...
Another font that may hit that is in the Properties of a CMD window.
Please use the Communities guidelines when posting.
http://www.microsoft.com/wn3/locales...help_en-us.htm
Use the "Ratings" feature. It helps the new users.
Mark L. Ferguson MS-MVP
https://mvp.support.microsoft.com/profile/Mark.Ferguson
"_CragTheCode" <cragniceh@xxxxxx> wrote in message
news:BC2155DF-9B79-4A27-B701-995881DE5600@xxxxxx
> on screen.
> Windows setting.
> Any clue?
Old 10-30-2008   #3 (permalink)
Zaphod Beeblebrox
> Autocad (a engineering drafting software):
> line on screen.
> Windows setting.
> Any clue?
It is likely due to the display you are using and the screen resolution
you have set in Windows. For example, if you are using a CRT display
(most of which are designed around a 4/3 width to height aspect ratio)
and you are running Windows in 1280x1024 (an aspect ratio of 5/4),
everything will look a little bit too wide because your pixel dimensions
end up being rectangular. If you switch to 1024x960, everythign will
square up.
Hope this helps!
Zaphod
No matter where you go, there you are!
Old 10-30-2008   #4 (permalink)
Zaphod Beeblebrox
And what exactly does a font have to do with the aspect ratio of a
drawing displayed on a screen?
Zaphod
"Mark L. Ferguson" <MarkLFerguson@xxxxxx> wrote in
message news:CAD01871-F2A5-4F3E-A91F-5497D1A3A97F@xxxxxx
>> line on screen.
>> Windows setting.
>> Any clue?
Old 10-30-2008   #5 (permalink)
Colon Terminus
> on screen.
> Windows setting.
> Any clue?
If you're using a wide-screen monitor, make sure you're using a wide-screen
resolution.
For example a wide-screen resolution would be 1680X1050.
A 4:3 (non wide-screen) ratiio would be 1280X960.
1280X1024 is NOT a proper ratio for anything.
Right-click on a blank area of your desktop.
Choose "Personalize" from the menu.
Choose "Display Settings" from the menu.
Make any adjustments necessary
Posted via NewsDemon.com - Premium Uncensored Newsgroup Service
------->>>>>>http://www.NewsDemon.com<<<<<<------
Unlimited Access, Anonymous Accounts, Uncensored Broadband Access
Old 10-31-2008   #6 (permalink)
_CragTheCode
im using LCD (not wide screen) with 1152x864.
This issue did not appear before i upgraded from xp to vista.
"Zaphod Beeblebrox" <Zaphod.Arisztid.Beeblebrox@xxxxxx> wrote in message
news:gecacs$64p$1@xxxxxx
>> on screen.
>> Windows setting.
>> Any clue?
> (most of which are designed around a 4/3 width to height aspect ratio) and
> you are running Windows in 1280x1024 (an aspect ratio of 5/4), everything
> will look a little bit too wide because your pixel dimensions end up being
> rectangular. If you switch to 1024x960, everythign will square up.
> Hope this helps!
> Zaphod
Old 10-31-2008   #7 (permalink)
Zaphod Beeblebrox
newsF257B89-1738-470A-B791-B6830D905E81@xxxxxx
> message news:gecacs$64p$1@xxxxxx
>>> line on screen.
>>> in Windows setting.
>>> Any clue?
>> resolution you have set in Windows. For example, if you are using a
>> CRT display (most of which are designed around a 4/3 width to height
>> aspect ratio) and you are running Windows in 1280x1024 (an aspect
>> ratio of 5/4), everything will look a little bit too wide because
>> your pixel dimensions end up being rectangular. If you switch to
Did you change screen resolution when you changed to Vista? 1152x864 is
not a native resolution for any LCD displays I've seen. I'd change to
the native resolution and see how it looks.
Zaphod
Old 10-31-2008   #8 (permalink)
Zaphod Beeblebrox
"Colon Terminus" <Colon_Terminus@xxxxxx> wrote in message
news:490a0a42$0$28846$b9f67a60@xxxxxx
Interesting statement - my Samsung SyncMaster 915N's native resolution
is 1280x1024. Why would that not be "proper"?
Zaphod
Arthur: All my life I've had this strange feeling that there's something
big and sinister going on in the world.
Slartibartfast: No, that's perfectly normal paranoia. Everyone in the
universe gets that.
Change default folder icon from Vista vertical to XP horizontal? Vista General
Help! Is this true? Embedded pics won't scale down to fit screen? Vista mail
Blank screen or vertical lines Vista General
Blurry fonts when changing DPI scale with LCD screen Vista General
Blurry fonts when changing DPI scale with LCD screen Vista hardware & devices
