| | Cannot turn microphone on, please help. Dear All. I was playing about with a USB microphone yesterday with little success. In order to stop the built in microphone from interfering I disabled it. Now I cannot enable it. If I go into sound devices and look under the recording tab, there are no devices to select and enable. Can anyone help, please. AMcF |
| Vista Home Premium 32bit | Re: Cannot turn microphone on, please help. I switched off speech recognition and now can't enable it and, as with Alex, I can't find a device to select and enable in sound devices. Any help, please! |
| Vista Home Premium 32bit | Re: Cannot turn microphone on, please help. Have found a solution, I went into sound devices/recording tab. In that window I right clicked and a box popped up showing disabled microphones. All you have to do is enable them again. |
| | Re: Cannot turn microphone on, please help. Thanks for letting us know - it may well help others. SteveT |
| Cannot Turn Microphone Off | Vista General | |||
| Microphone won't turn off | Vista General | |||
| how to turn off microphone recording? | Vista General | |||
| How to turn off microphone recording? | Vista General | |||
