Vista - Anyone yet discovered a solution to the Vista scheduler problem?
Old 11-08-2008   #1 (permalink)
JethroUK©
Anyone yet discovered a solution to the Vista scheduler problem - being that
if ever you log out or reboot (and login again), the scheduler 'forgets' the
user privileges & so any/all attempts to resume the schedule fail, fail,
fail, fail, grrrrrrrrrrrrrrrrrr
This was documented when Vista first appeared & reported solution was just
keep resetting the user every time - but it sorta defeats the object of an
otherwise automated scheduled task
I have tried setting the user as 'system' (as per defrag task, etc) but
that doesn't work either
Solution to WMP 11 problem in Vista General Discussion
Using Vista x64.... need a solution for my problem Vista General
New Features Discovered in Windows XP SP3: Is It Better Than Vista? Vista General
Vista: Task Scheduler Problem Vista account administration
Re: Just discovered this NG - a question about getting Vista Vista General
