Problems with PC Freezing
  1. #1
    Felixstowe
    Vista Ultimate 32bit.
    Local Time: 02:13 AM
    uk england
    I have a recurring problem that is now happening daily. My pc will sometimes freeze when left on slide show or when moving the mouse quickly over the screen. I have to manual switched off, I have tried different mice but this makes no difference. I have scanned for spyware etc and tried different mice. Can anyone shed any light on this?
    Many thanks
  2. #2
    Peter Foldes Guest
    Re: Problems with PC Freezing
    How much RAM do you have installed???
    Peter
    Please Reply to Newsgroup for the benefit of others
    Requests for assistance by email can not and will not be acknowledged.
    "HACKS" <guest@xxxxxx-email.com> wrote in message news:8586c1883c4fc1abdcca7f3d1923b1e1@xxxxxx-gateway.com...
    > ::I have a recurring problem that is now happening daily. My pc will
    > etc and tried different mice. Can anyone shed any light on this?::
    > ::Many thanks::
    > HACKS
  3. #3
    Mary Guest
    RE: Problems with PC Freezing
    The mouse is closely related to your video. Try updating or reinstalling your
    video driver. You should also recheck the Mouse settings in Control Panel.
    > ::Many thanks::
    > HACKS
  4. #4
    the wharf rat Guest
    In article <8586c1883c4fc1abdcca7f3d1923b1e1@xxxxxx-gateway.com>,
    Sure. All you need is a wrench and... Just kidding :-)
    This one should be in the event logs. Look in the "system" and
    "application" error logs and see if there is a message with a red X next to it.
  5. #5
    Felixstowe
    uk england
      Thread Starter
    this is the message i get
    hpqddsvc service hang report
    any one come across this before ?
    Cheers Marc
  6. #6
    Malke Guest
    The service belongs to your HP printer. You might try
    uninstalling/reinstalling the printer, getting the latest drivers from HP's
    website. If that doesn't help, contact HP tech support.
    Malke
    MS-MVP
    Elephant Boy Computers - Don't Panic!
    FAQ - http://www.elephantboycomputers.com/#FAQ
  7. #7
    Senior Member
    Bartlett
    vista home premium 64 oem
    Local Time: 03:13 AM
    usa us tennessee
    how to remove the hpqddsvc serivce hang report in Windows Vista?
    This site has a free 7 day trial but a yellow caution flag
  8. #8
    Felixstowe
    uk england
      Thread Starter
    Thanks to all who have replied to this tread so far. I have a new problem WdiServiceHost, again the Pc stopped working when i moved the mouse. I have also moved the mouse usb to another on the pc and have reistaled the driver.The mouse poniter also has a habbit of moveing pon the screen on its own. I have scanned for virus and use NOD 32 anit virus
    Thanks again
  9. #9
    Malke Guest
    > virus
    That is the Vista Diagnostic Service Host (WdiServiceHost). It sounds as
    though you may have hardware issues, but there really is no way for me to
    accurately diagnose your computer from here. I very much doubt that it has
    anything to do with your mouse. It could be a software issue (drivers,
    malware) but since you are having lockups with various services, I would
    start by testing your RAM and then your hard drive. Overheating can also
    cause freezes.
    Back up your data first.
    http://www.elephantboycomputers.com/...ardware_Tshoot
    Standard disclaimer: I can't see and test your computer myself, so these are
    just suggestions based on many years of being a professional computer tech;
    suggestions based on what you've written. You should not take my
    suggestions as a definitive diagnosis. Testing hardware failures often
    involves swapping out suspected parts with known-good parts. If you can't
    do the testing yourself and/or are uncomfortable opening your computer,
    take the machine to a professional computer repair shop (not your local
    equivalent of BigComputerStore/GeekSquad).
    Malke
    MS-MVP
freezing problems & start up problems CindyRB8603 Vista performance & maintenance 0 19 Mar 2010
freezing problems alexkgc27793 General Discussion 1 05 Aug 2009
problems with cursor freezing dwarner265 Vista General 1 17 Jun 2008
Freezing problems NOT fixed on RC2! Heywood Vista General 8 15 Oct 2006
Freezing problems NOT fixed on RC2! Heywood Vista hardware & devices 4 10 Oct 2006
