Vista Tutorial - Problem with copying the Vista 5728 iso file to external hard drive
Old 09-26-2006   #1 (permalink)
Chris
Guest
I downloaded the 5728 iso and checked its MD5 using DigestIT.
The MD5 was correct.
Then I copied the iso file to an external hard drive.
The filesize was correct, but the MD5 was different.
I copied it three times to the external hard drive.
Each time the filesize was correct, but the MD5 was different.
Any ideas?
Chris
Old 09-26-2006   #2 (permalink)
Chris
Guest
Re: Problem with copying the Vista 5728 iso file to external hard drive
In article <uQNLk0Ar$LGFFwKW@[127.0.0.1]>, Chris <nospam@[127.0.0.1]>
writes
>Any ideas?
Copying from another machine to Ext HDD worked OK.
Where it didn't work I had the Ext HDD connected to a USB hub.
Could that make a difference?
Chris
Old 09-26-2006   #3 (permalink)
Rock
Guest
> writes
>>Any ideas?
> Chris
Sounds like it did. Try it without the hub.
Rock [ MVP User/Shell]
Old 09-27-2006   #4 (permalink)
Chris
Guest
In article <eLH0P#d4GHA.2264@TK2MSFTNGP02.phx.gbl>, Rock
<rock@nospam.net> writes
>>writes
>>>Any ideas?
Tried it without hub. Worked. Are hubs often problematical?
Chris
Old 09-27-2006   #5 (permalink)
Mark D. VandenBerg
Guest
"Chris" <nospam@[127.0.0.1]> wrote in message
news:lZJAX3BVBnGFFwLa@[127.0.0.1]...
> Chris
Sometimes hubs don't pass enough power through to the device.
Mice/keyboards, not an issue. I have had problems with a headset/microphone
combo, my wireless gamepad, my webcam, etc... not working properly through a
hub. Never tried an external drive, though.
Old 09-27-2006   #6 (permalink)
Tom Lake
Guest
If it draws its power from the USB port it could be.
A hub that requires an external power supply to operate shouldn't be a
problem.
Tom Lake
Old 09-28-2006   #7 (permalink)
Rock
Guest
"Chris" wrote
>Rock writes
>>"Chris" wrote
>>> Chris writes
>>>>Any ideas?
You haven't said if it's a powered or non powered hub. Non powered hubs can
have more issues than powered ones, but even powered ones can be
problematic. Sometimes it depends on which hub it is. Also USB can be
flaky in XP. They never really got it nailed down to rock solid stability.
Old 09-28-2006   #8 (permalink)
Chris
Guest
In article <OCufT6r4GHA.3604@TK2MSFTNGP03.phx.gbl>, Rock
>"Chris" wrote
>>Rock writes
>>>"Chris" wrote
>>>> Chris writes
>>>>>Any ideas?
>hubs can have more issues than powered ones, but even powered ones can
>be problematic. Sometimes it depends on which hub it is. Also USB can
>be flaky in XP. They never really got it nailed down to rock solid
>stability.
Powered - but with the power turned off.
But that shouldn't matter - because the external hard drive has its own
power brick.
Chris
Copying Folder to External Hard Drive Vista file management
External Hard Drive problem - need help General Discussion
External Hard Drive PROBLEM ~~ Need HELP! Vista General
External Hard Drive Problem Vista hardware & devices
