| | Please HELP! Seagate external Back up Drive I just purchased a seagate Free Agent Go Drive 250G external drive. After over 2 hours on the fone with Seagate, they say it is a Microsoft problem. The error message is this: The application has failed to start because its side-by-side configuration is incorrect. Does ANYONE have a suggestion for me. otherwise, I guess I'll just return the drive. Thank you! |
| | Re: Please HELP! Seagate external Back up Drive Google this: "side-by-side configuration is incorrect" It might help. -- Paul's XP and Vista Tweaks --------------------------------------- www.paulsxp.com Paul's XP and Vista Help Forum -------------------------------------------- www.paulsxp.com/forum Live Support ------------------ www.paulsxp.com/livesupport.html "kenc" <kenc@xxxxxx> wrote in message news:4F52A7E9-9E14-4330-B6CA-6DA752A6198C@xxxxxx Quote: > I just purchased a seagate Free Agent Go Drive 250G external drive. > After > over 2 hours on the fone with Seagate, they say it is a Microsoft problem. > The error message is this: The application has failed to start because > its > side-by-side configuration is incorrect. Does ANYONE have a suggestion > for > me. otherwise, I guess I'll just return the drive. Thank you! |
| | Re: Please HELP! Seagate external Back up Drive What application failed to start? Can you be more specific? Did you install new software? If you did NOT install new software, do you see the same error when FreeAgent USB HD isn't attached? I seriously doubt SideBySide errors has anything to do with your new external HD unless you install new software that comes with the drive. Perhaps you can download and install Microsoft Visual C++ runtime components from the following: http://www.microsoft.com/downloads/d...displaylang=en "kenc" <kenc@xxxxxx> wrote in message news:4F52A7E9-9E14-4330-B6CA-6DA752A6198C@xxxxxx Quote: >I just purchased a seagate Free Agent Go Drive 250G external drive. After > over 2 hours on the fone with Seagate, they say it is a Microsoft problem. > The error message is this: The application has failed to start because > its > side-by-side configuration is incorrect. Does ANYONE have a suggestion > for > me. otherwise, I guess I'll just return the drive. Thank you! |
| | Re: Please HELP! Seagate external Back up Drive "kenc" <kenc@xxxxxx> wrote in message news:4F52A7E9-9E14-4330-B6CA-6DA752A6198C@xxxxxx Quote: > I just purchased a seagate Free Agent Go Drive 250G external drive. After > over 2 hours on the fone with Seagate, they say it is a Microsoft problem. > The error message is this: The application has failed to start because its > side-by-side configuration is incorrect. Does ANYONE have a suggestion for > me. otherwise, I guess I'll just return the drive. Thank you! http://forums.techarena.in/operating...ms/1000450.htm Tom Lake |
| Seagate External Hard Drive installation | Drivers | |||
| Seagate external drive does not work on Vista 64-bit | General Discussion | |||
| seagate freeagent external hard drive just stopped connecting | Vista General | |||
| Problem with automatic backup on a Seagate External Hard Drive | Vista hardware & devices | |||
| driver for Seagate external drive? | Vista hardware & devices | |||
