HD Problem and application Freezup
  1. #1
    JoeP Guest
    Hi All,
    I have Windows Vista Ultimate 64 bits.
    From time to time I have some freeze up of the application. So I ran the
    CHKDSK when the computer was rebooting and did not see any message from the
    CHKDSK that there was any problem. Also 2 days ago I could not BOOT since
    some service could found in the HD and the OS suggested running a CHKDSK
    that one was installed in drive D. Before that I got some messages from
    Vista that temporarily the application could not get access to the drive.
    Such as Word Document or Visual Studio.
    After the CHKDSK was running and I got this message just before logging in.
    Configuring updates
    Stage 1 of 3 0% complete
    What was that message all about?
    How can I check completely the HD which is from Western Digital 150GB,
    Raptor 10000 RPM.
    Is that really could be an HD problem? Checking with the McAfee does not
    seem I have a Virus.
    Thanks,
    Joe
  2. #2
    Malke Guest
    Re: HD Problem and application Freezup
    JoeP wrote:
    > Hi All,
    > the CHKDSK that there was any problem. Also 2 days ago I could not BOOT
    > since some service could found in the HD and the OS suggested running a
    > CHKDSK that one was installed in drive D. Before that I got some messages
    > from Vista that temporarily the application could not get access to the
    > drive. Such as Word Document or Visual Studio.
    > in.
    > Configuring updates
    > Raptor 10000 RPM.
    1. Back up your data.
    2. Run a diagnostic utility downloaded from the drive mftr.'s website. You
    will create a bootable CD with the file you download. You will need
    third-party burning software to do this such as Roxio, Nero, or the free
    CDBurnerXP Pro. Burn as an image, not as data.
    http://www.cdburnerxp.se/
    Boot with the CD you made and do a thorough test of the drive. If it fails
    any physical tests, replace it.
    Malke
    MS-MVP
    Elephant Boy Computers - Don't Panic!
    FAQ - http://www.elephantboycomputers.com/#FAQ
  3. #3
    AJR Guest
    From your post "...> Configuring updates
    > Stage 1 of 3 0% complete..." . You are receiving automatic updates which
    > are installed in "stages" usually prior to shutdown. If you are not
    > doing so - let update installation proceed.
    "Malke" <malke@xxxxxx> wrote in message
    news:%23cNzy5oRJHA.4372@xxxxxx
    > JoeP wrote:
    >> Hi All,
    >> in.
    >> Configuring updates
    >> Raptor 10000 RPM.
    > Malke
    > MS-MVP
  4. #4
    JoeP Guest
    Hi There,
    Thanks for the answer.
    I went to this link
    http://support.wdc.com/product/downl...sid=30&lang=en and
    created a bootable cd. The problem is it is looking at drive A instead of
    drive C. My computer does not have drive A. As you see in the above link
    that it is Data Lifeguard Diagnostic for DOS (CD).
    I am getting a message: Can not load the file A:\Command.com. I guess that
    iso file does not have all required files or that I missed something...
    Anybody has an idea? (I burned that using Roxio)
    Thanks,
    Joe
    > JoeP wrote:
    >> Hi All,
    >> in.
    >> Configuring updates
    >> Raptor 10000 RPM.
    > Malke
    > MS-MVP
  5. #5
    Malke Guest
    JoeP wrote:
    > Hi There,
    > I went to this link
    > that
    If you burned the .iso properly - with third-party burning software as an
    image, not as data - then you simply need to set your computer to boot from
    the CD drive first, just the way the instructions at the above link said.
    You do this in the BIOS Setup.
    Each computer has its own way of entering the BIOS. Look for a message when
    you first turn on the computer. It will say something like "Press F2 to
    enter Setup". Press that key and look for the Boot Priority or Boot Order
    in the BIOS. Put the optical drive first, hard drive second. Some computers
    also give you the ability to temporarily change the boot order when you
    first start the machine without entering the BIOS Setup by pressing a
    different key, for ex. F12. You'll then get a boot menu where you can
    select which device should be first for that one time.
    Accessing the BIOS
    http://michaelstevenstech.com/bios_manufacturer.htm
    http://www.uktsupport.co.uk/reference/biosp.htm
    http://www.computerhope.com/issues/ch000235.htm
    Malke
    MS-MVP
  6. #6
    JoeP Guest
    Hi Malke,
    Thanks for your reply.
    I created a bootable dvd actually using Roxio 9 and the option that I was choosing was: Burn from disk image file. Under creator classic.
    Then it was booted from the dvd but it tried to look for drive A. In this link http://support.wdc.com/product/downl...sid=30&lang=en I downloaded this file: Data Lifeguard Diagnostic for DOS (CD)
    Maybe Western digital placed the wrong install file! does it make sense? Yes and I went to the BIOS and changed the boot sequence to be the first priority as the DVD.
    What else is there?
    Thanks,
    Joe
    "Malke" <malke@xxxxxx> wrote in message news:OhToo1%23RJHA.1160@xxxxxx
    > JoeP wrote:
    >> Hi There,
    >> I went to this link
    >> that
    > Accessing the BIOS
    > Malke
    > MS-MVP
HD Problem and application Freezup problems?
Freezup during installation? Sulazoh Vista installation & setup 1 01 Mar 2010
Graphic Problem on application bar angyecarm Vista performance & maintenance 0 08 Sep 2009
Problem installing .exe application Sarah0622 General Discussion 3 23 Jun 2009
Application Problem jlhawk Software 2 28 Jul 2008
Bitlocker Application Problem srini Vista security 0 25 Aug 2007
