| | Rc1 ugrade failed, rollback failed... Help? First, let me say that I used the Upgrade Advisor and got rid of everything I was told needed to go before Rc1 was attempted. I then tried to do the RC1 upgrade on my XPsp2 box and it froze up. I left it at about 3/4 done on the progress bar for over 36 hours. I finally decided to restart the computer. Upon reboot the setup told me it had failed and was going to roll back to xp. That also failed and now I get a command box. I have tried all the boot options (previous windows verstion - nothing ever happened... rollback - nothing, and recovered vista - nothing) I know that my XP and docs were backed up during the upgrade process. At this point I just want my computer back... Does anyone know the steps to make that happen? |
| | RE: Rc1 ugrade failed, rollback failed... Help? Sorry for all of the duplicates, the posting said it failed and like a noob i kept trying... "theDon" wrote: > First, let me say that I used the Upgrade Advisor and got rid of everything I > was told needed to go before Rc1 was attempted. I then tried to do the RC1 > upgrade on my XPsp2 box and it froze up. I left it at about 3/4 done on the > progress bar for over 36 hours. I finally decided to restart the computer. > Upon reboot the setup told me it had failed and was going to roll back to xp. > That also failed and now I get a command box. I have tried all the boot > options (previous windows verstion - nothing ever happened... rollback - > nothing, and recovered vista - nothing) > > I know that my XP and docs were backed up during the upgrade process. At > this point I just want my computer back... > > Does anyone know the steps to make that happen? |
| Rc1 ugrade failed rollback to XP failed | Vista General | |||
| Rc1 ugrade failed, rollback failed... Help? | Vista General | |||
| install failed,rollback failed | Vista installation & setup | |||
| Install failed rollback failed | Vista installation & setup | |||
| Installation Failed at Extracting Files - rollback failed dismally | Vista installation & setup | |||
