| | java problem is it possible to install java on windows vista... i use live streaming for shares and it uses java... Use the following settings in your Internet Browser (mandatory) 1. Sun JVM must be disabled : Go to Internet Browser. --> Tools --> Internet Options --> Advanced --> Java (Sun). (Change this setting only if aforesaid setting are found) 2. Enable Microsoft VM : Go to Internet Browser --> Tools --> Internet Options --> Advanced --> Java Console enabled. Go to Internet Browser --> Tools --> Internet Options --> Advanced --> Java Logging enabled. Go to Internet Browser --> Tools --> Internet Options --> Advanced --> JIT complier for virtual machine enabled. i dont find this option in ie7... can anyone help....thnks -- sunny_cs ------------------------------------------------------------------------ sunny_cs's Profile: http://forums.techarena.in/member.php?userid=17866 View this thread: http://forums.techarena.in/showthread.php?t=595134 http://www.techarena.in |
| | Re: java problem "sunny_cs" <sunny_cs.2er2fh@DoNotSpam.com> wrote in message news:sunny_cs.2er2fh@DoNotSpam.com... > > is it possible to install java on windows vista... i use live streaming > for shares and it uses java... I think Java beta 6 is the one you need. |
| | Re: java problem It seems better to direct the request to www.java.com rather than vista? MS can't change Java, Java can change Java? |
| | Re: java problem On Tue, 26 Sep 2006 21:33:18 +0530, sunny_cs <sunny_cs.2er2fh@DoNotSpam.com> wrote: > >is it possible to install java on windows vista... Yes, but get the full setup, not the online one (worked for 5.0u6 and 5.0u8 |
| Sun Java Install Problem | Software | |||
| updating java problem | Vista General | |||
| java installation problem | Vista installation & setup | |||
| Vista-Java problem | Vista performance & maintenance | |||
| Java Programming Problem | Vista security | |||
