Vista - M2N32 SLI DELUXE WIFI LIMITED CONECTION PROBLEM
Old 09-26-2006   #1 (permalink)
=?Utf-8?B?TEFVUkVOVA==?=
I HAVE INSTALLED VISTA RC1 32BIT and i get the limited conection problem.
windows xp works fine!
Part of the drivers where installed but the realtek 8187 program does not
run on vista, just the drivers.
i have tried many manual options, like dns, gateway, ip etc but cant even
get to the admin page of the us robotics adsl router
please help!
Old 09-26-2006   #2 (permalink)
Conor
Re: M2N32 SLI DELUXE WIFI LIMITED CONECTION PROBLEM
In article <E9E849C0-AE37-40C2-AFC0-BEE0DA845517@microsoft.com>,
LAURENT says...
> please help!
Get Vista drivers from Realtek.
Conor
I'm really a nice guy. If I had friends, they would tell you.
Earn commission on online purchases, £2.50 just for signing up:
http://www.TopCashBack.co.uk/Conor/ref/index.htm
Old 09-26-2006   #3 (permalink)
> LAURENT says...
> > please help!
> Conor
THANKS ...BUT NOT MUCH USE AS REALTEK HAS NO DRIVERS FOR VISTA!
ANY OTHER HELP PLEASE??
Old 09-26-2006   #4 (permalink)
=?Utf-8?B?QnJlbnQ=?=
Hopefully your problem isn't Vista having trouble connecting to certain
wireless networks. I have that issue, it connects fine with most wireless
networks but not one that is important to me (and works perfect under xp).
Problem typically occurs with Open/WEP/hidden SSID.
Take care,
Brent
"LAURENT" wrote:
> > LAURENT says...
> > > please help!
> > Conor
M2N32-SLI Deluxe 4GB memory install General Discussion
Support CD for Asus M2n32 deluxe Drivers
Motherboard SocketAM2 M2N32-SLI Deluxe Vista installation & setup
M2N32 SLI DELUXE WIFI LIMITED CONECTIVITY PROBLEM Vista General
M2N32 SLI Deluxe ( Vista beta 2 x64) Vista General
