A sound problem
  1. #1
    Jimshirl29 Guest
    A sound problem
    I have installed the drivers for a sound card I have called 24-Envy24 Family
    Controller. It is compatible with Vista and everything works fine, but when
    I boot up again it loads a High Definition Audio Device which doesn't work
    and I uninstalled but keeps coming back.
    Any suggestions?
  2. #2
    John Barnes Guest
    Re: A sound problem
    Have you checked in the BIOS to see if you turned off the MOBO sound. Often
    you have problems if both are enabled.
    "Jimshirl29" <jimshirl29@xxxxxx> wrote in message
    news:%23afKC4MSJHA.3300@xxxxxx
    >Family Controller. It is compatible with Vista and everything works fine,
    >but when I boot up again it loads a High Definition Audio Device which
    >doesn't work and I uninstalled but keeps coming back.
    > Any suggestions?
A sound problem
5.1 sound problem again Sizo Sound & Audio 0 21 Jun 2009
Sound problem madx Vista General 2 19 Jul 2008
An UN Sound Problem Anopheles Vista performance & maintenance 0 13 Apr 2008
Sound problem Ron Vista performance & maintenance 2 06 Jan 2008
5.1 sound problem with Realtek ACL655 on board sound Stubby Vista hardware & devices 0 16 Jun 2006
