| Vista Home Premium 32bit | Aero Animation Problems Hi there, I know Aero is enabled on my PC, as the transparency is enabled and the glass feature. I'm running Vista Home Premium 32bit with 2.4Ghz dual core processor and 9600GT card, with 2Gigs of RAM, I know that my PC can run Aero easily, but I just don't know why the minimizing / opening animations aren't working. Doesn't matter which program I use, Firefox, windows itself (folders etc) the animations just don't happen, and the windows show immediately without any fade. Can anyone help me with this? Thanks in advance, Jack |
| | Re: Aero Animation Problems Hello, Please try this: - Click start - Right-click computer (in the black area) - Click properties - In the left of the window that appears, click advanced system settings - Click the Settings button inside the box for performance - Make sure there is a checkmark next to 'animate windows when minimizing and maximizing' - JB "Schmoopy" <guest@xxxxxx-email.com> wrote in message news:bf155401e578c7f7ddaa383f59a58a99@xxxxxx-gateway.com... Quote: > > Hi there, I know Aero is enabled on my PC, as the transparency is > enabled and the glass feature. I'm running Vista Home Premium 32bit with > 2.4Ghz dual core processor and 9600GT card, with 2Gigs of RAM, I know > that my PC can run Aero easily, but I just don't know why the minimizing > / opening animations aren't working. Doesn't matter which program I use, > Firefox, windows itself (folders etc) the animations just don't happen, > and the windows show immediately without any fade. > > Can anyone help me with this? > > Thanks in advance, > > Jack > > > -- > Schmoopy |
| Vista Home Premium 32bit | Re: Aero Animation Problems Yup, all the check boxes are ticked |
| | Re: Aero Animation Problems Did you do a restart or a log off and log back in? Although its not necessary, sometimes it helps. Best regards, Andre Da Costa http://adacosta.spaces.live.com "Schmoopy" <guest@xxxxxx-email.com> wrote in message news:ae3b307b9f2836f8e2102753b556a118@xxxxxx-gateway.com... Quote: > > Yup, all the check boxes are ticked ![]() > > > -- > Schmoopy |
| Vista Home Premium 32bit | Re: Aero Animation Problems Yup, restarted but no change, thanks for the replies. |
| | #6 (permalink) |
| Vista Home Premium 32bit | Re: Aero Animation Problems Bump, help please :P |
| | #7 (permalink) |
| Vista Home Premium 32bit | Re: Aero Animation Problems Bump |
| | #8 (permalink) |
| Vista Home Premium 32bit | Re: Aero Animation Problems Bump... still no solution |
| | #9 (permalink) |
| | Re: Aero Animation Problems Schmoopy wrote: Quote: > Bump... still no solution ![]() > > Or are you just curious? And what's with all the bumps? Bill |
| | #10 (permalink) |
| Vista Home Premium 32bit | Re: Aero Animation Problems It's not a huge thing, but it should be working on Aero, and since it doesn't seem to be a common thing there must be something wrong |
| Vista Aero Problems | General Discussion | |||
| Vista Aero Windows Minimization Animation Strangeness | Vista General | |||
| aero problems | Vista General | |||
