Vista Forums Home Join Vista Forums Tech Publications Windows 7 Forum Vista Tutorials Webcasts Tags
Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Integrated search does not work
Update your Vista Drivers
Thread Tools Display Modes
Old 09-26-2006   #1 (permalink)
Roof Fiddler
Guest
Running Vista RC1, I inserted my Windows XP CD, and in Vista went to
Start/Search/Advanced Search, specified the CD as the search location,
checked "Include non-indexed, hidden, and system files", and searched for
winhlp32.exe. The search came up empty. There was a button "search inside
file contents", so I clicked that, and Vista read the CD for a while and
then displayed two matches, both named MIGWIZ.INF, and probably neither of
which contains winhlp32.exe, considering that the size of each is 5kB. I
tried right-clicking on those matches, and nothing happened, and I tried
left double-clicking on them, and nothing happened. So it won't even let me
view the contents of those files.
I know that Vista is able to see inside cab files, because even in Explorer
the cab files can be opened like folders and the contents viewed.
So, searching through files which are all in Microsoft's own formats, on
Microsoft's own CD, Vista's integrated search can't find a file which I know
is somewhere on the CD.
If Vista's search can't even find something as simple as winhlp32.exe on the
Windows XP CD, then what good is it?
Am I supposed to find a spare machine and install Windows XP on it, just so
I can boot it up and run dir /s winhlp32.exe and copy the file from it? Is
this really the extent of the sophistication of Microsoft's search
technologies?
Ironically, the old help program was removed from Vista because Microsoft
was afraid it might have bugs which could allow malicious help files to take
control of the help program. But isn't the point of the revamped security in
Vista to prevent a malicious program (such as a buggy help program which has
been commandeered by a malicious help file) from damaging the user's system,
programs, or data?
No, wait, I'm mistaken; that's not the point. Vista is still explicitly
designed to allow any program which a user runs to trash all of the user's
data files, which might be irreplaceable, though not trash any of the
program or system files, even though they're all available on installation
DVDs lying beside the user's computer.
Old 09-26-2006   #2 (permalink)
deebs
Guest
Re: Integrated search does not work
Ouch! It still seems reasonable, to me, for programs and OS to reside
on one platter and user(s) data on another.
It would on the face of it seem to provide a pragmatic and practical
solution
Old 09-26-2006   #3 (permalink)
Rock
Guest
"Roof Fiddler" <fiddler@roof.com> wrote in message
news:OSq7ZZb4GHA.3592@TK2MSFTNGP05.phx.gbl...
> me view the contents of those files.
> Explorer the cab files can be opened like folders and the contents viewed.
> know is somewhere on the CD.
> the Windows XP CD, then what good is it?
> so I can boot it up and run dir /s winhlp32.exe and copy the file from it?
> Is this really the extent of the sophistication of Microsoft's search
> technologies?
> take control of the help program. But isn't the point of the revamped
> security in Vista to prevent a malicious program (such as a buggy help
> program which has been commandeered by a malicious help file) from
> damaging the user's system, programs, or data?
Did you search for winhlp32.ex_? That's the normal form for files on the XP
CD, in a compressed format. I found that in about 2 seconds using vista's
search. It's 128 KB. I don't believe the file winhlp32.exe is on the CD.
Rock [ MVP User/Shell]
Old 09-27-2006   #4 (permalink)
Roof Fiddler
Guest
"Rock" <rock@nospam.net> wrote in message
news:e9a4zNd4GHA.3364@TK2MSFTNGP02.phx.gbl...
> XP CD, in a compressed format. I found that in about 2 seconds using
> vista's search. It's 128 KB. I don't believe the file winhlp32.exe is on
> the CD.
I noticed winhlp32.ex_ after posting my message, and found on MS's web site
instructions to use "expand" to uncompress it. So that did solve my
immediate problem.
But my point was that MS's own compression format (and idiotic compressed
file naming convention) defeats MS's own search program. That's about as
lame as it would be to fail to search inside cab files or industry-standard
zip files (surely Vista's search can at least find files contained in zip
files?)
What's the point in having a search program if I have to manually look
through all the files to find what I'm looking for anyway?
Old 09-27-2006   #5 (permalink)
John Barnes
Guest
Compressed files are automatically expanded by windows and don't use the
expand command. .cab files do require the expand command.
The file with the _ character may not give you the correct file. The
install program will select the correct version of some files based on the
system being install onto.
I haven't found the Vista search to be very satisfactory for my use. I
personally much prefer the XP version.
news:eaIYvAk4GHA.3964@TK2MSFTNGP04.phx.gbl...
>> on the CD.
> site instructions to use "expand" to uncompress it. So that did solve my
> immediate problem.
> industry-standard zip files (surely Vista's search can at least find files
> contained in zip files?)
Old 09-28-2006   #6 (permalink)
Rock
Guest
>> on the CD.
> immediate problem.
Uhh..you need to know what it is you're looking for. If the file is named
one way search for it that way. You expect it to think for you too?
Old 09-28-2006   #7 (permalink)
Rock
Guest
>>> the XP CD, in a compressed format. I found that in about 2 seconds
>>> using vista's search. It's 128 KB. I don't believe the file
>> immediate problem.
>> files contained in zip files?)
We get many complaints about XP's search being dumbed down from previous
versions, and often the recommendation is to use the free Agent Ransack. I
haven't tried it in Vista yet. I think the Vista search is pretty good
compared to XPs. There is a learning curve with it but indexed it's fast.
Old 09-28-2006   #8 (permalink)
John Barnes
Guest
Maybe if everything is indexed, but not indexed it takes much longer to get
results. I often find myself looking for something on another installed
system (on another volume) and it takes forever to find. Searching on the
CD/DVD will never be indexed.
news:ePJrL2r4GHA.2264@TK2MSFTNGP02.phx.gbl...
>> the system being install onto.
>>> immediate problem.
>>> compressed file naming convention) defeats MS's own search program.
>>> That's about as lame as it would be to fail to search inside cab files
>>> or industry-standard zip files (surely Vista's search can at least find
> I haven't tried it in Vista yet. I think the Vista search is pretty good
Old 09-28-2006   #9 (permalink)
Rock
Guest
"John Barnes" <jbarnes@email.net> wrote in message
news:OJq4QSv4GHA.1256@TK2MSFTNGP04.phx.gbl...
> get results. I often find myself looking for something on another
> installed system (on another volume) and it takes forever to find.
> Searching on the CD/DVD will never be indexed.
>>>> my immediate problem.
>> fast.
Yes that is true, but the problems with CD/DVD are the same with XP.
Old 09-28-2006   #10 (permalink)
Rock
Guest
>> immediate problem.
I installed Agent Ransack in Vista x86 build 5728. Works fine so far.
Display Modes
Re: Search does not work Mr. Arnold Vista General 1 10-27-2007 11:05 PM
How do you get Search For: to work Bob Landau PowerShell 2 09-13-2007 06:12 PM
Still searching for way to get Vista search to work: Why doesn't FilterFilesWithUnknownExtensions registry key work in Vista? Celegans Vista General 11 08-31-2007 10:04 AM
Vista integrated desktop search =?Utf-8?B?VmlubmllVA==?= Vista file management 0 09-18-2006 10:46 AM
search does not work jsemmanuel Vista file management 4 07-10-2006 09:02 AM
Complimentary Industry Resources
Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today!
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
