| | Safely Remove Hardware - USB flash drive "in use" Hi all Many times when I come to 'Safely Remove Hardware' (USB pen drive) it is reported as in use (when it is not) and will not allow me to stop/eject the drive. Explorer is closed and no apps that I can see are accessing the pen drive... (indexing?). I end up pulling it out anyway ;-) An annoying bug - does not do this with XP either. Guy |
| | Re: Safely Remove Hardware - USB flash drive "in use" "Bigguy" <bigguy36@xxxxxx> wrote Quote: > Many times when I come to 'Safely Remove Hardware' (USB pen drive) it is > reported as in use (when it is not) and will not allow me to stop/eject > the drive. > Explorer is closed and no apps that I can see are accessing the pen > drive... (indexing?). aware of it are the Recycle Bin and System Restore... -- Bob http://www.kanyak.com |
| 64bit | Re: Safely Remove Hardware - USB flash drive "in use" Restoring the Safely Remove Hardware Icon So, tell me, has your Safely Remove Hardware icon ever disappeared from your system tray? You know, the icon you use to safely disconnect your USB devices. Even though your device is still plugged in, the icon is gone and you're left stranded without a safe way to remove it. So, what do you do? Well, most people go ahead and pull the device out on their own, but that's really not the proper way to do it. Doing that can cause severe damage to your hardware. Luckily, there's an easy way to get your Safely Remove Hardware icon back up and running. Try this! To restore your Safely Remove Hardware icon, go to your Start menu, right click on it and choose Properties. Next, click on the Taskbar tab at the top of the dialogue window. Once you've done that, click on the Customize button. In the Customize Notification(s) dialogue box, scroll down until you come across the Safely Remove Hardware option. Next, click on the down arrow next to it and select Always Show. Then click OK. The Safely Remove Hardware icon will then reappear in your system tray and you can go back to removing your hardware the right way. Oh yeah! |
| | Re: Safely Remove Hardware - USB flash drive "in use" I'll tell you when it is definitely a problem. If the device is a thumb drive you will rarely get the thumb drive corrupted and you can always go back to the source and get what was on the thumb. Ipods or Apple little devices almost never. But if you do this enough times with an external hard drive and you've backed up significant files and folders to it, you may find that hd corrupted, and unless you're a recovery expert and have the expensive tools and odds are you aren't, people want $1500-$1700 bucks to recover them. There are videos on the web that may or may not work for you. CH "Bigguy" <bigguy36@xxxxxx> wrote in message news:6ofe46F3d5k4U1@xxxxxx Quote: > Hi all > > Many times when I come to 'Safely Remove Hardware' (USB pen drive) it is > reported as in use (when it is not) and will not allow me to stop/eject > the drive. > > Explorer is closed and no apps that I can see are accessing the pen > drive... (indexing?). > > I end up pulling it out anyway ;-) > > An annoying bug - does not do this with XP either. > > Guy > |
| hard drives showing in "safely remove hardware" | Vista hardware & devices | |||
| Question about "safely remove hardware" icon | Vista General | |||
| Remove hardware from "Safely Remove Hardware" list | Vista hardware & devices | |||
| The "Safely Remove Hardware" in taksbar's system tray... | Vista General | |||
| Can't they provide an option to remove "Safely Remove Hardware"? | Vista General | |||
