Power "bumps"
  1.    19 Nov 2008 #1
    Best Guest
    Power "bumps"
    How can I change the settings, so when there is a power bump (lights flicker
    for a second) the computer shuts off and stays off, rather than starts
    again?
  2.    19 Nov 2008 #2
    Earle Horton Guest
    Re: Power "bumps"
    That is usually a BIOS setup thing, and depends on the particular
    motherboard that you have. Look in your motherboard manual, or press
    usually ESC or DEL on startup. Some of them have weird key combinations.
    Earle Horton -- earleh@xxxxxx
    "Best" <doyucare@xxxxxx> wrote in message
    news:%233gUmdqSJHA.4452@xxxxxx
    > flicker for a second) the computer shuts off and stays off, rather than
    > starts again?
  3.    19 Nov 2008 #3
    Best Guest
    Re: Power "bumps"
    "Earle Horton" <earleh@xxxxxx> wrote in message
    news:uqXwPfqSJHA.5056@xxxxxx
    Thanks, will do. I seem to remember that from a few computers back, thought
    they would have upgraded it by now.
  4.    19 Nov 2008 #4
    Jed Guest
    Re: Power "bumps"
    >again?
    Your best bet would be to buy a UPS backup power supply that would
    allow you the time to save any open files and shutdown gracefully.
  5.    19 Nov 2008 #5
    Peter Foldes Guest
    Re: Power "bumps"
    Best
    Windows+Pause key and select Advanced\Startup and Recovery\Settings and put a checkmark to ""Automatically Restart""
    Peter
    Please Reply to Newsgroup for the benefit of others
    Requests for assistance by email can not and will not be acknowledged.
    "Best" <doyucare@xxxxxx> wrote in message news:%233gUmdqSJHA.4452@xxxxxx
    > again?
  6.    19 Nov 2008 #6
    Richard Urban Guest
    Re: Power "bumps"
    If you are asking this question the problem must be severe. Get a good UPS
    power backup and end your problems.
    Richard Urban
    Microsoft MVP
    Windows Desktop Experience
    > starts again?
  7.    19 Nov 2008 #7
    the wharf rat Guest
    Re: Power "bumps"
    In article <#3gUmdqSJHA.4452@xxxxxx>,
    >again?
    I trained my cat to pull the plugs out when the lights flicker.
  8.    20 Nov 2008 #8
    illjilli Guest
    Re: Power "bumps"
    you are correct. Folders is not.. as usual.
    "Zaphod Beeblebrox" <Zaphod.Arisztid.Beeblebrox@xxxxxx> wrote in message
    news:gg3noo$dhn$1@xxxxxx
    > "Peter Foldes" <okf22@xxxxxx> wrote in message
    > news:uTlRKUrSJHA.5244@xxxxxx
    >>> flicker
    >>> again?
    >> Best
    > Peter: That has nothing to do with what the OP is asking. That setting
    > controls what Windows does when it bugchecks / blue screens. You need to
    > learn to read posts more carefully.
    > Best: The setting you are looking for is in the PC's BIOS settings. During
    > a boot, you'll need to press a key, usually the DEL key or F2,etc. - it
    > depends on your computer, but it normally tells you during the boot before
    > Windows starts loading.
    > Zaphod
    > No matter where you go, there you are!
  9.    20 Nov 2008 #9
    Ian D Guest
    Re: Power "bumps"
    > starts again?
    There should be a setting in the BIOS Power menu. It
    will be labelled something like, Restore on AC power loss.
    The default is usually, Power off, but your's must be set
    to resart, or power on.
  10.    08 Dec 2008 #10
    Best Guest
    Re: Power "bumps"
    "Jed" <zyzygy@xxxxxxôtentiary.com.invalid> wrote in message
    news:m7d9i4pca789k0p0ucbrufahdvaf45uo8b@xxxxxx
    >>flicker
    >>again?
    I am more concerned about the times when I am not home.
Power "bumps"
Windows "recovers from an unexpected shutdown" with no Power, Network, & Volume Icons
Hey, Lately I have been starting to get a notification - "Windows recovered from an unexpected shutdown" - after waking up my computer. It...
General Discussion
Server stuck on "Installing update 1 of 3...Please do not power off"
Out of hours last night I chose to install the latest Windows updates (from Tuesday 8th September) on our SBS 2008 server. The server hadn't been...
SBS Server
Unwanted Multiple contacts in "To","CC","BCC" of email send catago
In the email "Contacts" address listing my contacts are listed one time which is fine. When I "Create" a new email or "Forward", "Reply" or "Reply...
Vista mail
Defaulting Power Shell's "elevation" mode
We've just got a new Windows 2008 RTM Server setup and are trying to install our ASP.NET application which uses a Power Shell script that calls IIS...
PowerShell
Vista not wotking with "My Computer" or "Control Panel", "Screen Saver"
HI Folks, When I try to check contents of "My Computer", "Control Panel" the screen does a 1 second display then disappears back the Start screen....
Vista General
Power Options Page "Fails To Load"
Start->Control Panel->Power Options A window opens and writes "The page failed to load." WTF?? Isn't that much like the Intel processor...
Vista General
Question about "Turn off display" by Vista Power Plan
I found a problem regarding to turn off display by Vista Power Plan on a laptop PC: 1. I set the display off after 1 min when AC plugged. 2. I...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • Old server
    About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
