Vista Tutorial - Re: Need help. Trying not to spend another $250!!!
Old 11-20-2008   #1 (permalink)
Andre Da Costa
Guest
If you have a Windows Vista installation disc, you need to restart (boot)
your computer using the installation disc. If you do not restart your
computer from the disc, the option to repair your computer will not appear.
If you have a Windows installation disc:
Insert the installation disc.
Restart your computer by clicking the Start button , clicking the arrow next
to the Lock button , and then clicking Restart.
If prompted, press any key to start Windows from the installation disc.
Note
If your computer is not configured to start from a CD or DVD, check the
information that came with your computer. You may need to change your
computer's BIOS settings. For more information, see BIOS: frequently asked
questions.
Choose your language settings, and then click Next.
Click Repair your computer.
Select the operating system you want to repair, and then click Next.
On the System Recovery Options menu, click a tool to open it.
If your computer has preinstalled recovery options:
Remove all floppy disks, CDs, and DVDs from your computer, and then restart
your computer by clicking the Start button , clicking the arrow next to the
Do one of the following:
If your computer has a single operating system installed, press and hold the
F8 key as your computer restarts. You need to press F8 before the Windows
logo appears. If the Windows logo appears, you will need to try again by
waiting until the Windows logon prompt appears, and then shutting down and
restarting your computer.
If your computer has more than one operating system, use the arrow keys to
highlight the operating system you want to repair, and then press and hold
F8.
On the Advanced Boot Options screen, use the arrow keys to highlight Repair
your computer, and then press ENTER. (If Repair your computer is not listed
as an option, then your computer does not include the System Recovery
Options menu as a preinstalled recovery option.)
Select a keyboard layout, and then click Next.
Select a user name and enter the password, and then click OK.
Best regards,
Andre Da Costa
http://adacosta.spaces.live.com
"RHW3714" <djheat3714@xxxxxx> wrote in message
news:RHW3714.3j6jnr@xxxxxx-mx.tabletquestions.com...
Quote:
> My computer running Windows Vista Home Premium is having a boot problem
> including kl1 and the other Kaspersky drivers yada yada yada and I know
> how to fix it. I can uninstall Kaspersky and it should go away. One
> problem with this. I can only run in Safe mode. How do I get the
> Windows Installer to work in safe mode?
> RHW3714
How much to spend on Vista? Vista General
Controling Quantity of Time a Child is allowed spend on comp each Vista General
