Please help with wierd problem - window stuck with title bar only
  1. #1
    Joe Guest
    For some reason Vista's onscreen keyboard window has become locked in
    a title bar with no way to expand it:
    http://img389.imageshack.us/my.php?image=oskpiccs5.jpg
    I've tried every think I can think of short of reinstalling Vista.
  2. #2
    Joe Guest
    Re: Please help with wierd problem - window stuck with title bar only
    "Bina" <binah57@xxxxxx> wrote:
    > I know this is most unlikely... but if you have two monitors
    > then the on-screen keyboard may be open on the other monitor
    > which could be switched off.
    I do have multiple monitors but this wasn't the problem. Anyway after
    a bit of trial & error I was able to find a key in the registry to
    delete that did the trick, thanks though.
Please help with wierd problem - window stuck with title bar only problems?
Get window title from PID roger.pray VB Script 1 14 Apr 2009
Wierd thing(Can't think of a title) eldron General Discussion 2 30 Oct 2008
Re-setting the window title when PSCX is installed Duncan Smith PowerShell 2 08 Apr 2008
Updating window title bar to current location Marc Scheuner PowerShell 2 30 Dec 2007
How do I change the colours of window title bars? =?Utf-8?B?aW1hY2tlbg==?= Vista General 9 24 Jul 2006
