| | System Restore Error - vista home premium This is a new pc - preloaded with vista home premium. I've had the pc a couple weeks and every time i've tried to restore my system to an earlier point, It does its thing... then after re-boot, it says... Encountered an Error Unable to restore to previous state It doesn't seem to matter what type of restore point i use. I have a large HD and have the restore options set correctly... Also, it does seem to restore some things, so i'm not sure what the error message is about. (For example, the windows updates that were recently installed, are no longer installed) appreciate any help thanks |
| | Re: System Restore Error - vista home premium If the points are no good, turn off sys restore, restart, and turn it back on, and test restore. -- Use the "Ratings" feature. It helps the new users. Please use the Communities guidelines when posting. http://www.microsoft.com/wn3/locales...help_en-us.htm Mark L. Ferguson MS-MVP https://mvp.support.microsoft.com/profile/Mark.Ferguson "jstewart335" <jstewart335@xxxxxx> wrote in message news 5F154A6-AEEA-4822-80D2-6A51633901FE@xxxxxxQuote: > This is a new pc - preloaded with vista home premium. > I've had the pc a couple weeks and every time i've tried to restore my > system to an earlier point, It does its thing... then after re-boot, it > says... > > Encountered an Error > Unable to restore to previous state > > It doesn't seem to matter what type of restore point i use. I have a large > HD and have the restore options set correctly... > Also, it does seem to restore some things, so i'm not sure what the error > message is about. (For example, the windows updates that were recently > installed, are no longer installed) > > appreciate any help > thanks > |
| | RE: System Restore Error - vista home premium thx guys. ....will try both suggestions |
| System restore on vista home premium sp1 | General Discussion | |||
| System Restore Issue in Vista Home Premium | Vista performance & maintenance | |||
| Cannot do system restore due to Group Policy Vista Home Premium | Vista General | |||
| System Restore Doesn't work Vista Home Premium | Vista security | |||
| System restore error on Vista home premium | Vista General | |||
