Vista - repair auto play settings
Old 11-28-2008   #1 (permalink)
keepout
I had Nero showtime set as the default to autoplay DVD's.
I upgraded via uninstall to a different version of Nero showtime
the autoplay settings GRAYED out the OLD showtime, and I want to fix it so it
runs the installed showtime.
The autoplay wizard dated 2003 from Microsoft won't even run on Vista.
Is there a known registry entry for the autoplay settings, or specifically the
2 grayed out entries I have on all Older Nero autoplay settings ?
more pix @ http://members.toast.net/cbminfo/index.html
Old 11-28-2008   #2 (permalink)
Black Vista version
Re: repair auto play settings
Nero is got to be one of the top 3 most bloated crapware out there.
Number 1 is vista number 2 is norton products
You should use your serial number with the nero lite or micro version..
google it.
<keepout@xxxxxx> wrote in message
news:vme0j41b1vrjv1lal1b2v0s18bk7davdff@xxxxxx
> it
> the
Old 11-28-2008   #3 (permalink)
John Inzer
> it so it runs the installed showtime.
> specifically the 2 grayed out entries I have on all Older Nero
> autoplay settings ?
Maybe the following articles will offer some ideas:
Windows Vista -
AutoPlay: frequently asked questions
http://tinyurl.com/2ol3dx
or...
http://windowshelp.microsoft.com/Win...ddd971033.mspx
Windows Vista -
How To Change AutoPlay Settings
http://tinyurl.com/5s7ssz
or...
http://windowshelp.microsoft.com/Win...f2ac81033.mspx
Windows Vista :
How to customize AutoPlay
http://www.vista4beginners.com/AutoPlay
John Inzer MS-MVP
Digital Media Experience
Notice
This is not tech support
I am a volunteer
Solutions that work for
me may not work for you
Proceed at your own risk
Old 11-28-2008   #4 (permalink)
oscar
RE: repair auto play settings
The link that you supplied offers nothing for posters to understand the
condition of your OS, except that it is quite likely that problems with your
Vista and your older programs may be self-inflicted.
oscar
....Right click is your very good friend...
Old 11-28-2008   #5 (permalink)
keepout
>> autoplay settings ?
>Windows Vista -
> or...
NO
Quote:
>Windows Vista -
> or...
NO
Quote:
>Windows Vista :
And NO
I removed a previous version of Nero [showtime] that set itself up as the
DEFAULT to play a DVD.
I installed a DIFFERENT version of Nero [showtime] and I can only assume it saw
in the registry that it already was the DEFAULT, or the registry key already
existed, so it moved on and left the old broken registry key alone.
I need to get down to the root problem. Vista doesn't know it's broken.
I need to find the autoplay registry entries to fix Any and ALL grayed out
entries.
Old 11-28-2008   #6 (permalink)
keepout
On Fri, 28 Nov 2008 11:55:01 -0800, oscar <oscar@xxxxxx>
I didn't provide any links.
I installed Nero, it set showtime as the default for DVD player which I wanted.
I uninstalled that version of Nero and installed a different Nero.
Now the default player [showtime] is grayed out in the autoplay section of
vista. It points to where the REMOVED Nero showtime existed.
Old 11-28-2008   #7 (permalink)
Vista Bussiness x64 PL
I don't know but may this soft help you to find it->http://windowsxp.mvps.org/autoplayhandlers.htm
Old 11-28-2008   #8 (permalink)
silver hair
Hi
Just a Comment
I use Revo Uninstaller to Remove Programs
It all so finds Registry Entry's and other crap, so I can delete it if I want
http://www.revouninstaller.com/
Cyberlink Power2Go,
came Installed in my Factory installed Vista Home Basic 32 bit
Don.t read much about Power2Go here, may be not much used
Just a comment
lucky me I guess
Auto Play Settings General Discussion
Auto repair fails and copy big files to usb problem Vista General
auto play Software
Auto Play and Auto Run Vista Games
Corrupt install, can't auto-repair Vista installation & setup
