| | USB external hard drive causes extreme CPU useage Windows Vista Home Premium on a Dell XPS M1530 laptop. The title basically says it all. Whilst using an external USB hard drive, Process Explorer gives the CPU useage in the 90% -plus range. It's a dual core system, and it appears to only be using one core at full useage, as the temps are in the high 50's and low 60's (celcius), and full useage of both cores typically puts the temps into the 70's. What's the reason for this? Indexing? Does the CPU need to be doing this, and is there a way to stop it? I use the external hard drive for videos, music and photos so the contents are not being used permanently. is there a way to stop this CPU useage, and if so, would it affect performance much? |
| | Re: USB external hard drive causes extreme CPU useage I could suggest leaving it turned on for a long time, so that the OS can index the drive to its little heart's content. Otherwise, you might be able to do something in Control Panel, System, Performance, Adjust Indexing Options. Cheers, Earle "Cuzman" <cuzGETRID@xxxxxx> wrote in message news:R5edncs-x68nqK7UnZ2dnUVZ8iydnZ2d@xxxxxx Quote: > > Windows Vista Home Premium on a Dell XPS M1530 laptop. > > The title basically says it all. Whilst using an external USB hard drive, > Process Explorer gives the CPU useage in the 90% -plus range. > > It's a dual core system, and it appears to only be using one core at full > useage, as the temps are in the high 50's and low 60's (celcius), and full > useage of both cores typically puts the temps into the 70's. > > What's the reason for this? Indexing? Does the CPU need to be doing > this, and is there a way to stop it? I use the external hard drive for > videos, music and photos so the contents are not being used permanently. > is there a way to stop this CPU useage, and if so, would it affect > performance much? |
| Vista Bussiness x64 PL | Re: USB external hard drive causes extreme CPU useage Quote: The title basically says it all. Whilst using an external USB hard drive, Process Explorer gives the CPU useage in the 90% -plus range |
| Connecting to shared hard drive with Apple Airport Extreme Base Station. | Vista networking & sharing | |||
| hard drive 100% useage SUPER DUPER LAG | General Discussion | |||
| Complete PC Backup to external hard drive: share the drive? | Vista General | |||
| Converting my external USB FAT external hard drive to NFTS | Vista hardware & devices | |||
| External DVD Drive / Hard Drive Vista Install | Vista General | |||
