| | help with Admin priveleges I'm trying to uninstall previous versions of Java thru control panel/uninstall programs - but it keeps saying that I don't have admin priveleges and won't let me . I'm running Vista Home Premium I've tried googling - and tried to follow a couple of the geek squad ideas of getting the hidden admin to come out of hiding ... but to no avail can someone help me figure out how to uninstall various programs and get to the real admin? My user acct of course says it has admin priv - but that must not be the case? pam |
| | Re: help with Admin priveleges From Start/.../RUN, you type: Net user administrator /active:yes OK that and restart After you uninstall what you want, the reverse is: Net user administrator /active:no -- Use the "Ratings" feature. It helps the new users. Please use the Communities guidelines when posting. http://www.microsoft.com/wn3/locales...help_en-us.htm Mark L. Ferguson MS-MVP https://mvp.support.microsoft.com/profile/Mark.Ferguson "Pam" <staley007@xxxxxx> wrote in message news:44F3549D-2575-4775-906E-26943E805B9F@xxxxxx Quote: > I'm trying to uninstall previous versions of Java thru control > panel/uninstall programs - but it keeps saying that I don't have admin > priveleges and won't let me . I'm running Vista Home Premium > > I've tried googling - and tried to follow a couple of the geek squad ideas > of getting the hidden admin to come out of hiding ... but to no avail > > can someone help me figure out how to uninstall various programs and get > to > the real admin? My user acct of course says it has admin priv - but that > must not be the case? > > pam > |
| | Re: help with Admin priveleges Quote: >From Start/.../RUN, you type: > >Net user administrator /active:yes > >OK that and restart > >After you uninstall what you want, the reverse is: > >Net user administrator /active:no the RUN menu. Might be better to get the command prompt from Accessories->Command Prompt then rt-click to access "Run As Administrator" first. |
| | Re: help with Admin priveleges On Fri, 5 Dec 2008 13:06:30 -0600, "Mark L. Ferguson" <MarkLFerguson@xxxxxx> wrote: Quote: >From Start/.../RUN, you type: > >Net user administrator /active:yes > >OK that and restart > >After you uninstall what you want, the reverse is: > >Net user administrator /active:no the "NET" command - something that was intended for network related operations - to enable a local administrator account? Also, how long does the enable last if not deactivated? Until reboot? |
| | Re: help with Admin priveleges (Thanks to M.L. for backing me up on that, I'm going to claim a 'senior moment' :/) +Bob+ It lasts till deactivated. I find you comment nicely put. I often wondered why a 'workgroup' (LAN rather than a 'Domain') did not have a 'chairman' or 'speaker'. Someone to kind of 'lead the voting' of the members. Each member is the admin of their own machine, and 'dominates' that area of the data, but that is true of any group gathering, computer driven or not. Certainly the NET command will also 'start' or 'stop' a Local service, so user activation is just one step up from there. I agree with the need to 'dominate' activity on a Domain, but the lack of a clear leader on a workgroup was always a rather curiously missing component. -- Mark L. Ferguson MS-MVP https://mvp.support.microsoft.com/profile/Mark.Ferguson "+Bob+" <nomailplease@xxxxxx> wrote in message news:5dfjj4hjr3eso83etkjajt25k3090moo7o@xxxxxx Quote: > On Fri, 5 Dec 2008 13:06:30 -0600, "Mark L. Ferguson" > <MarkLFerguson@xxxxxx> wrote: Quote: >>Net user administrator /active:no > I won't deny that that works, but what's the strategy behind MS using > the "NET" command - something that was intended for network related > operations - to enable a local administrator account? > > Also, how long does the enable last if not deactivated? Until reboot? > > |
Administrative Priveleges | General Discussion | |||
| Why does it say I need admin priveleges when I know I have them? | Vista account administration | |||
| Does sharing folders required admin priveleges? | Vista networking & sharing | |||
| You do not have sufficient priveleges..... | Vista account administration | |||
| Debugging priveleges | Vista performance & maintenance | |||
