Vista - Installation hangs - Please help!!!
Old 09-28-2006   #1 (permalink)
=?Utf-8?B?SW5zdGFsbGF0aW9uIGhhbmdz?=
I have installed Vista 4 times now (2 times from the network and 2 times from
CD) but everytime when it get to "Completing installation", it reboots and
then the screen goes blank. I left it that way for an hour or so and then
tried to reboot. Not it says that "an error was encountered or it was
shutdown.... so i can restart my installation"
Can anybody please help??
Old 10-03-2006   #2 (permalink)
=?Utf-8?B?a2VqYQ==?=
RE: Installation hangs - Please help!!!
(Saw your post on WUGNET but I haven't a password for that...)
You mention a Toshiba Satellite - is that an M40? If so, others have had the
same problem but there is a workaround for it.
Boot from the Vista dvd, choose install, then repair. Cancel the startup
check, then choose the advanced repair options, then Command Line.
From there you can delete (or rename, but that doesn't always work) the
PCMCIA.SYS file in
Windows\system32\drivers and
windows\system32\driverstore\filerepository\pcmcia.inf_539d553e [numbers may
vary according to the build you are using].
Old 10-03-2006   #3 (permalink)
I have A105-s4164 - does it still work? I just completed installing Windows
XP... but if this works, i can give it a shot...
Thanks!
> PCMCIA.SYS file in
Old 10-03-2006   #4 (permalink)
Hmm, the A105 is a much newer model (described as Vista-ready?) and so the
problem may be something totally different...
The pcmcia driver causing the problem on the M40 is Texas Instruments
PCI-xx21/xx11 CardBus Controller with UltraMedia. If yours is the same it
might be worth a try.
NOTE: If you have just finished re-installing XP it really would be a good
idea to leave XP alone and make a new partition for a dual-boot XP/Vista
set-up. As you will have to replace Vista when it is officially released it
is easier to keep it separate. (sorry if I'm stating the obvious or you have
other reasons.)
> Thanks!
> > PCMCIA.SYS file in
Old 10-03-2006   #5 (permalink)
Oh, and I think the SD card reader piggy-backs on that, but I don't know the
driver details.
Old 10-03-2006   #6 (permalink)
Is SD - sound? Piggy back on which one?
Thanks for your help!
> driver details.
Old 10-03-2006   #7 (permalink)
No, I think SD has to do with the smart card reader on the front edge, and I
thought that was also Texas Instruments like the pcmcia slot but can't find
the details.
The sound card (on mine, SoundMax Integrated) downloaded and installed the
driver automatically when I first went online.
> > driver details.
Old 10-04-2006   #8 (permalink)
=?Utf-8?B?d2lsbGlhbQ==?=
I had the same problem a short time ago.
but I have solved it already
Here are my suggestions
1.format your destination partition.
2.begin your installation not in the Windows but before it(use boot from
CD-ROM)
3.take away as many plugs on your mother board as possible(especially in the
PCIs)
but be careful. If you use a dual boot and begin the installation
immediately after the formating without going to XP even once , the partition
name in vista WOULD NOT MATCH THOSE IN XP. for exmple ,if my XP is in the C
patition and I install vista in E. The vista will call the partition where it
is installed Partition C and the original C and D would be D and E etc.
More information from www_zj30@126.com (email)
Old 10-04-2006   #9 (permalink)
I have a notebook and not sure what you mean by plugs in a notebook. I am not
hooked to anything other than my power chord.
> CD-ROM)
> PCIs)
Old 02-21-2007   #10 (permalink)
bigdave
Vista hang, stalls or freeze
is your hard drive plugged into a SATA 2 socket. windows vista really hates them. i've reverted back to a standard SATA socket and changed the settings to non-RAID in the BIOS and vista starts every time without and hangs, stalls or freeze. Plus, up-to-date graphics drivers are ESSENTIAL. try running vista in safe mode to update. lots of people say safe mode runs fine.
EggHeadCafe.com - .NET Developer Portal of Choice
http://www.eggheadcafe.com
Yet another Vista hangs during installation General Discussion
Installation Hangs Vista installation & setup
Installation/Upgrade Hangs Vista installation & setup
Installation hangs - please help!!! Vista General
Installation hangs Vista installation & setup
