| | Installation hangs - please help!!! I have installed Vista 4 times now (2 times from the network and 2 times from CD) but everytime when it get to "Completing installation", it reboots and then the screen goes blank. I left it that way for an hour or so and then tried to reboot. Not it says that "an error was encountered or it was shutdown.... so i can restart my installation" Can anybody please help?? |
| | RE: Installation hangs - please help!!! Details please. Are you upgrading? Clean install? What version of Vista? "Installation hangs" wrote: > I have installed Vista 4 times now (2 times from the network and 2 times from > CD) but everytime when it get to "Completing installation", it reboots and > then the screen goes blank. I left it that way for an hour or so and then > tried to reboot. Not it says that "an error was encountered or it was > shutdown.... so i can restart my installation" > > Can anybody please help?? |
| | Re: Installation hangs - please help!!! "Installation hangs" wrote >I have installed Vista 4 times now (2 times from the network and 2 times >from > CD) but everytime when it get to "Completing installation", it reboots and > then the screen goes blank. I left it that way for an hour or so and then > tried to reboot. Not it says that "an error was encountered or it was > shutdown.... so i can restart my installation" > > Can anybody please help?? Also what hardware? Did you run the upgrade advisor? -- Rock [ MVP User/Shell] |
| | Re: Installation hangs - please help!!! How about if you try booting into safe mode? I could be a bad display that's causing the screen to go blank. "Installation hangs" <Installationhangs@discussions.microsoft.com> wrote in message news:7D129B33-CAD5-457E-8DB7-E8804150FFB8@microsoft.com... >I have installed Vista 4 times now (2 times from the network and 2 times >from > CD) but everytime when it get to "Completing installation", it reboots and > then the screen goes blank. I left it that way for an hour or so and then > tried to reboot. Not it says that "an error was encountered or it was > shutdown.... so i can restart my installation" > > Can anybody please help?? |
| | RE: Installation hangs - please help!!! I had the same. Try disabling the onboard sound and usb while installing. You can enable them after the installation has finished. I managed this way to complete the installation but it didn't solve all my problems though. "Installation hangs" wrote: > I have installed Vista 4 times now (2 times from the network and 2 times from > CD) but everytime when it get to "Completing installation", it reboots and > then the screen goes blank. I left it that way for an hour or so and then > tried to reboot. Not it says that "an error was encountered or it was > shutdown.... so i can restart my installation" > > Can anybody please help?? |
| | #6 (permalink) |
| | RE: Installation hangs - please help!!! Did you disable it through the system utility? Can you please tellme the steps? To answer other questions: 1. It was a clean install (i formatted the drive) 2. I can't open it even in safe mode coz it says installation cannot continue in safe mode 3. I am installing 5600 RC1 build Your help is appreciated! "ReMeE" wrote: > I had the same. Try disabling the onboard sound and usb while installing. You > can enable them after the installation has finished. I managed this way to > complete the installation but it didn't solve all my problems though. > > "Installation hangs" wrote: > > > I have installed Vista 4 times now (2 times from the network and 2 times from > > CD) but everytime when it get to "Completing installation", it reboots and > > then the screen goes blank. I left it that way for an hour or so and then > > tried to reboot. Not it says that "an error was encountered or it was > > shutdown.... so i can restart my installation" > > > > Can anybody please help?? |
| | #7 (permalink) |
| | RE: Installation hangs - please help!!! I looked at my system utilities and i don't have any option to disable sound - the only one is see is the legacy usb support and i disabled it - tried to do a clean install again and doesn't work. "Installation hangs" wrote: > Did you disable it through the system utility? Can you please tellme the steps? > > To answer other questions: > 1. It was a clean install (i formatted the drive) > 2. I can't open it even in safe mode coz it says installation cannot > continue in safe mode > 3. I am installing 5600 RC1 build > > > Your help is appreciated! > > > "ReMeE" wrote: > > > I had the same. Try disabling the onboard sound and usb while installing. You > > can enable them after the installation has finished. I managed this way to > > complete the installation but it didn't solve all my problems though. > > > > "Installation hangs" wrote: > > > > > I have installed Vista 4 times now (2 times from the network and 2 times from > > > CD) but everytime when it get to "Completing installation", it reboots and > > > then the screen goes blank. I left it that way for an hour or so and then > > > tried to reboot. Not it says that "an error was encountered or it was > > > shutdown.... so i can restart my installation" > > > > > > Can anybody please help?? |
| | #8 (permalink) |
| | RE: Installation hangs - please help!!! You have to disable them in the Bios. "Installation hangs" wrote: > I looked at my system utilities and i don't have any option to disable sound > - the only one is see is the legacy usb support and i disabled it - tried to > do a clean install again and doesn't work. > > > "Installation hangs" wrote: > > > Did you disable it through the system utility? Can you please tellme the steps? > > > > To answer other questions: > > 1. It was a clean install (i formatted the drive) > > 2. I can't open it even in safe mode coz it says installation cannot > > continue in safe mode > > 3. I am installing 5600 RC1 build > > > > > > Your help is appreciated! > > > > > > "ReMeE" wrote: > > > > > I had the same. Try disabling the onboard sound and usb while installing. You > > > can enable them after the installation has finished. I managed this way to > > > complete the installation but it didn't solve all my problems though. > > > > > > "Installation hangs" wrote: > > > > > > > I have installed Vista 4 times now (2 times from the network and 2 times from > > > > CD) but everytime when it get to "Completing installation", it reboots and > > > > then the screen goes blank. I left it that way for an hour or so and then > > > > tried to reboot. Not it says that "an error was encountered or it was > > > > shutdown.... so i can restart my installation" > > > > > > > > Can anybody please help?? |
| | #9 (permalink) |
| | RE: Installation hangs - please help!!! I don't see an option for sound in bios. My version of BIOS is 1.9. My machine is a Toshiba Satellite. Can you please tell me how i can disable the sound. "ReMeE" wrote: > You have to disable them in the Bios. > > "Installation hangs" wrote: > > > I looked at my system utilities and i don't have any option to disable sound > > - the only one is see is the legacy usb support and i disabled it - tried to > > do a clean install again and doesn't work. > > > > > > "Installation hangs" wrote: > > > > > Did you disable it through the system utility? Can you please tellme the steps? > > > > > > To answer other questions: > > > 1. It was a clean install (i formatted the drive) > > > 2. I can't open it even in safe mode coz it says installation cannot > > > continue in safe mode > > > 3. I am installing 5600 RC1 build > > > > > > > > > Your help is appreciated! > > > > > > > > > "ReMeE" wrote: > > > > > > > I had the same. Try disabling the onboard sound and usb while installing. You > > > > can enable them after the installation has finished. I managed this way to > > > > complete the installation but it didn't solve all my problems though. > > > > > > > > "Installation hangs" wrote: > > > > > > > > > I have installed Vista 4 times now (2 times from the network and 2 times from > > > > > CD) but everytime when it get to "Completing installation", it reboots and > > > > > then the screen goes blank. I left it that way for an hour or so and then > > > > > tried to reboot. Not it says that "an error was encountered or it was > > > > > shutdown.... so i can restart my installation" > > > > > > > > > > Can anybody please help?? |
| | #10 (permalink) |
| | RE: Installation hangs - please help!!! I'm having this problem as well. I'm doing a clean install on a 2nd hd for duel boot. Only once have I been able to reboot once to continue install but after the 2nd reboot, it just has a black screen. I've tried 4 different times and even redownloaded the ISO file. I am using 5600 rc1 build from the microsoft website. any help or ideas would be much appreceated!!!! "Installation hangs" wrote: > I have installed Vista 4 times now (2 times from the network and 2 times from > CD) but everytime when it get to "Completing installation", it reboots and > then the screen goes blank. I left it that way for an hour or so and then > tried to reboot. Not it says that "an error was encountered or it was > shutdown.... so i can restart my installation" > > Can anybody please help?? |
| Yet another Vista hangs during installation | General Discussion | |||
| Installation Hangs | Vista installation & setup | |||
| Installation hangs - Please help!!! | Vista General | |||
| Installation/Upgrade Hangs | Vista installation & setup | |||
| Installation hangs | Vista installation & setup | |||
