Vista - Lost Volume, Network, Power icons from notification area
Old 12-11-2008   #1 (permalink)
CH
Vista 64 Ultimate/HP HDX 16 laptop
I can't get them back, right click start button, properties, notification
area, system icons - the three checkboxes are grayed out. Only the clock
checkbox is active... What to do? Thanks, --ch
Old 12-11-2008   #2 (permalink)
Vista Ultimate 32-bit
Re: Lost Volume, Network, Power icons from notification area
Quote  Quote: Originally Posted by CH View Post
Try to "kill" explorer.exe process bu pressing ctrl+shift+esc,find explorer.exe and select end process,still don't close Task Manager.
Now go to File menu in Task Manager,select New Tas (Run) and type explorer...press Enter.
Now you should see options un-grayed select them and click OK.Repeat this with selecting and reselecting and then restart PC.
Worked for me
Old 12-11-2008   #3 (permalink)
CH
"Lazaruslong" <guest@xxxxxx-email.com> wrote in message
news:7ebf73bc874f7f134f24bb8d65d6ea78@xxxxxx-gateway.com...
Quote:
>> notification
>> clock
> Try to "kill" *explorer.exe* process bu pressing *ctrl+shift+esc*,find
> explorer.exe and select end process,still don't close *Task Manager*.
> Now go to File menu in Task Manager,select *New Tas (Run)* and type
> Worked for me
> Lazaruslong
OK, that worked for now, thanks. Is this likely to re-occur often?
--ch
Old 12-12-2008   #4 (permalink)
Quote:
>> notification
>> clock
> Worked for me
> Lazaruslong
--ch
Unfortunately...yes.This happens to me 2-3 times in 1,5 year.Last time was before 2 days,after restart just disapears all icons including antivirus an other boot time powered apps except clock.Checked in Task Manager they was runing but not showed in tray
Continuing problems with Network, Power & Volume icons Vista General
Volume, network, and power icon missing from notificaion area Vista performance & maintenance
Who let the volume and network notification icons out? Vista General
Network, Volume and Power Greyed out on Notification Area Icons Vista General
Volume, Network and Power Icons and Booting up with Vista Vista General
