| Ultimate x64 | Itunes issues **NOT the Typical BSOD** I just setup a new system and got vista ultimate 64 up and running. Havent experienced any issues at all until i downloaded itunes. The program installs fine, however i have graphics and display issues with Itunes once it launches.,. I've uninstalled Itunes8 and reinstalled 7.7, and that didnt work either... Anyone experience this particular issue? How did you fix? |
| | Re: Itunes issues **NOT the Typical BSOD** Did you download and install the Vista 64-bit version from http://www.apple.com/itunes/download/ ? "flynnstone" <guest@xxxxxx-email.com> wrote in message news:4016f42b92c68c6b67f5bd6de1d817ea@xxxxxx-gateway.com... Quote: > > I just setup a new system and got vista ultimate 64 up and running. > Havent experienced any issues at all until i downloaded itunes. The > program installs fine, however i have graphics and display issues with > Itunes once it launches.,. I've uninstalled Itunes8 and reinstalled 7.7, > and that didnt work either... > > Anyone experience this particular issue? How did you fix? > > > -- > flynnstone |
| Ultimate x64 | Re: Itunes issues **NOT the Typical BSOD** Yeah, i've tried both 7.7 and 8.0 in 64bit. Same issue...The text is all jumbled and the graphics are jacked.... |
| Ultimate x64 | Re: Itunes issues **NOT the Typical BSOD** Here's a screenshot of my desktop with ITUNES launched... |
| | Re: Itunes issues **NOT the Typical BSOD** Go to you iTunes directory (usually C:\Program Files\iTunes), right-click on iTunes.exe, go to the compatibility tab and check "Run this program in compatibility mode for:" and then select Windows XP from the drop down box. Then launch iTunes from its directory (not shortcut in start menu or desktop). See if that works. "flynnstone" <guest@xxxxxx-email.com> wrote in message news:4016f42b92c68c6b67f5bd6de1d817ea@xxxxxx-gateway.com... Quote: > > I just setup a new system and got vista ultimate 64 up and running. > Havent experienced any issues at all until i downloaded itunes. The > program installs fine, however i have graphics and display issues with > Itunes once it launches.,. I've uninstalled Itunes8 and reinstalled 7.7, > and that didnt work either... > > Anyone experience this particular issue? How did you fix? > > > -- > flynnstone |
| | #6 (permalink) |
| Ultimate x64 | Re: Itunes issues **NOT the Typical BSOD** WELL that didnt work, it turned my screen green and crashed itunes... hRM Go to you iTunes directory (usually C:\Program Files\iTunes), right-click on iTunes.exe, go to the compatibility tab and check "Run this program in compatibility mode for:" and then select Windows XP from the drop down box. Then launch iTunes from its directory (not shortcut in start menu or desktop). See if that works. "flynnstone" <guest@xxxxxx-email.com> wrote in message news:4016f42b92c68c6b67f5bd6de1d817ea@xxxxxx-gateway.com... Quote: > > I just setup a new system and got vista ultimate 64 up and running. > Havent experienced any issues at all until i downloaded itunes. The > program installs fine, however i have graphics and display issues with > Itunes once it launches.,. I've uninstalled Itunes8 and reinstalled 7.7, > and that didnt work either... > > Anyone experience this particular issue? How did you fix? > > > -- > flynnstone |
| | #7 (permalink) |
| Ultimate x64 | Re: Itunes issues **NOT the Typical BSOD** anyone? |
| | #8 (permalink) |
| Ultimate x64 | Re: Itunes issues **NOT the Typical BSOD** helllllp! |
| | #9 (permalink) |
| | Re: Itunes issues **NOT the Typical BSOD** On Tue, 16 Dec 2008 11:15:11 -0600, flynnstone <guest@xxxxxx-email.com> wrote: Quote: > >helllllp! |
| | #10 (permalink) |
| | Re: Itunes issues **NOT the Typical BSOD** "flynnstone" <guest@xxxxxx-email.com> wrote in message news:c619e2eb16b4429b1310b76b4274b795@xxxxxx-gateway.com... Quote: > > helllllp! > > > -- > flynnstone ..... Mind asking a question? -- - Colton ! Reply to newsgroups * Remove stars in email |
| iTunes Digital Copy Issues | Vista General | |||
| BSOD issues w/new install | Drivers | |||
| itunes again! Burning to CD issues. | Software | |||
| Memory issues causing BSOD? | Vista hardware & devices | |||
| iTunes 7.6 + Vista x64 = BSOD! WARNING! | Software | |||
