Vista - System Restore error (create restore point), event ID: 8193
Old 12-14-2008   #1 (permalink)
Sven Pran
While struggling with Applicationn hung problems I have discovered that the
following error has frequently been reported (some 400 times) on my system
since June 11, 2008:
"Failed to create restore point on volume (Process =
C:\Windows\system32\rundll32.exe /d srrstr.dll,ExecuteScheduledSPPCreation;
Descripton = Scheduled Checkpoint; Hr = 0x80070422)."
(The parameters have varied)
I have followed the various tracks Event Viewer suggestions but am no more
the wiser.
Can somebody enlighten me on what is going on and what I can do about it?
(There is no apparent correlation between this error events and the
Applicaction hung events)
Regards Sven
Old 12-14-2008   #2 (permalink)
B. Smith
Re: System Restore error (create restore point), event ID: 8193
"Sven Pran" <no.direct@xxxxxx> wrote in message
news:69299A21-81A1-43F5-B945-04B0D061C6A7@xxxxxx
> the following error has frequently been reported (some 400 times) on my
> system since June 11, 2008:
> srrstr.dll,ExecuteScheduledSPPCreation; Descripton = Scheduled Checkpoint;
> Hr = 0x80070422)."
> the wiser.
> Regards Sven
How much free space remains on C drive ?
What is the size of your C drive ?
Old 12-14-2008   #3 (permalink)
Peter Foldes
Sven
You have a malware infection of some sort. That is what it is telling you
Read and decide
http://www.daniweb.com/forums/thread13479.html
Peter
Please Reply to Newsgroup for the benefit of others
Requests for assistance by email can not and will not be acknowledged.
> following error has frequently been reported (some 400 times) on my system since
> June 11, 2008:
> I have followed the various tracks Event Viewer suggestions but am no more the
> wiser.
> (There is no apparent correlation between this error events and the Applicaction
> hung events)
> Regards Sven
Old 12-14-2008   #4 (permalink)
Sven Pran
"B. Smith" <bsmith@xxxxxx> wrote in message
news:%23Wn0ugiXJHA.5476@xxxxxx
>> more the wiser.
>> Regards Sven
179GB
220GB
(In case this information is important I should add that my harddisk is
actually split into two partitions visible by Vista; the C: drive which is
named OS and a D: drive which is named RECOVERY with 5,50 GB free space out
of 9,99 GB.)
Sven
Old 12-14-2008   #5 (permalink)
B. Smith
news:udP94piXJHA.760@xxxxxx
>>> more the wiser.
>>> it?
>>> Regards Sven
> 179GB
> 220GB
> out of 9,99 GB.)
> Sven
Quote:
Click the Start Orb...type system...then click on System in the menu that
appears in the list.
In the window that appears...click System Protection....make sure in
available disk...C has a check mark.
Old 12-14-2008   #6 (permalink)
Sven Pran
That malware infection is in case extremely well hidden, it didn't show up
in any of my protection features during the full scans I did last night.
However I looked up the web-page in your link.
The easiest suggestion to try out first was to go to "Start" > "Control
Panel" > "Administrative Tools" > "Services", but I found no "System Restore
Service" (or similar) at all.
Next I went to "Start" > "Computer" > "Properties" > "System Protection"
where I found three "Available Disks" listed, all of which had "None" for
"Most recent restore point":
RECOVERY (D
OS (C (System)
OS (C (Missing)
Only the last one was checked, and I just don't understand the note
"Missing" or why I have two C: disks at all. Maybe the fact that this third
disk has an icon different from the two others means something?
Can the fact that I have a remote USB disk for backup purposes (Using
Acronis) have anything to do with this, this disk is normally not conneted.
I checked the OS (C (System) disk and clicked "Create" (restore point
right now), this operation was successful both according to a messagebox
showing up and also to "none" for "Most recent restore point" becoming
replaced by a timestamp.
My Event Viewer did not report any problem this time.
So what now? I still feel being in the dark.
regards Sven
"Peter Foldes" <okf122@xxxxxx> wrote in message
news:e7nFqkiXJHA.1184@xxxxxx
Quote:
> Sven
> Read and decide
> Peter
>> more the wiser.
>> Regards Sven
Old 12-14-2008   #7 (permalink)
B. Smith
news:ehrlX8iXJHA.2440@xxxxxx
> Restore Service" (or similar) at all.
> RECOVERY (D
> OS (C (System)
> OS (C (Missing)
> third disk has an icon different from the two others means something?
> conneted.
> regards Sven
Quote:
>> Sven
>> Read and decide
>> Peter
>>> more the wiser.
>>> it?
>>> Regards Sven
I think you are on to something.
I don't use acronis...but it has made the usb drive the system restore
drive.
Put a check in the first C drive listing....see if it takes...even after
using the usb backup.
Old 12-14-2008   #8 (permalink)
PaulB
Check the box next to C: system. Uncheck the one next to C: missing.
Did you reinstall Vista at anytime?
Paul
> RECOVERY (D
> OS (C (System)
> OS (C (Missing)
> regards Sven
Quote:
> > Sven
> > Read and decide
> > Peter
> >> more the wiser.
> >> Regards Sven
Old 12-14-2008   #9 (permalink)
B. Smith
"PaulB" <PaulB@xxxxxx> wrote in message
news:C30CD77A-E62C-4568-A9F8-7451AC573B69@xxxxxx
Quote:
> Hi,
Good one.
keep reading, my next answer will come to you.
2 hours after I post it.
Old 12-14-2008   #10 (permalink)
PaulB
Why be such an @$#. I didn't see your response before I posted or I wouldn't
have. I was in the middle of resposonding when I had to leave for a while.
Sorry, but I'm sure the same answer from two people didn't really hurt.
Paul
Quote:
> > Hi,
> Good one.
unable to create system restore point Vista General
Cannot Create System Restore Point (0x80042318) Vista performance & maintenance
System Restore Point - create Tutorials
Couldn't create a system restore point in Vista General Discussion
failed to create system restore point Vista security
