Vista - Need to create "Documents and Settings" folder on C drive
Old 12-14-2008   #1 (permalink)
MT
I need to create the "Document and Settings" folder on C drive in Vista.
When I try to do this is says it will move it to C:\users and does not let me
create it under "C:\".
I need this folder on C drive in order to open a project file in Power
Producer (video editing software) that I created on a PC using Windows XP.
Once I can create the Documents and Settings folder, then I can create the
full path and copy the required files in the last folder so Power Producer
can open the project that I have spent hours producing!!
There is no option in Power Producer to change where it looks for these
files for the project. My only hope to not waste the hours of work already
spent is to re-create the full path in Windows Vista, which means I need...
c:\Documents and Settings\...
Can anyone help me....please!!!!
Thanks,
MT
so I can re-create the eaxct path that the program Power Producer is
looking for.
Old 12-14-2008   #2 (permalink)
The Max
Re: Need to create "Documents and Settings" folder on C drive
On Sun, 14 Dec 2008 20:19:01 -0800, MT <MT@xxxxxx>
>Thanks,
>MT
Turn off User Account Control.
Control Panel (Classic mode), User Accounts.
Max
Old 12-15-2008   #3 (permalink)
The Max
On Mon, 15 Dec 2008 05:20:16 -0000, "Synapse Syndrome"
<synapse@xxxxxx> wrote:
Quote:
>The Max <max.imus@xxxxxx> wrote:
Quote:
>>> Vista. When I try to do this is says it will move it to C:\users and
>>> does not let me create it under "C:\".
>>> XP. Once I can create the Documents and Settings folder, then I can
>>> create the full path and copy the required files in the last folder
>>> so Power Producer can open the project that I have spent hours
>>> producing!!
>>> already spent is to re-create the full path in Windows Vista, which
>>> means I need... c:\Documents and Settings\...
>No. He cannot create the folder because there is a junction point in that
>location pointing to the new Vista location, for legacy apps. That is why
>the folder is being diverted when he tried to move it there. The Documents
>and Settings folder is now the Users folder in Vista. He can user the same
>old path in Vista, but it will be diverted to the new location.
Completely missed that. It's past my bed time I think ;-)
Old 12-15-2008   #4 (permalink)
Windows 7 , Vista
Quote  Quote: Originally Posted by The Max View Post
Hi -
You cannot create a folder named Documents and Settings on the c:\ root drive because there is a Vista Junction of the same name. This particular Junction redirects traffic pointing to c:\Documents and Settings to c:\Users.
To take a look for yourself, run the following command:
START | type cmd.exe | right-click on cmd.exe above under Programs | paste the following into the cmd/DOS screen (to paste, right-click at top of DOS screen, select Edit, select Paste):
Code:
dir c:\*. /a > %temp%\0.txt & start notepad %temp%\0.txt
A Notepad will open. Among the items you will see:
Code:
11/02/2006  10:42 AM    <JUNCTION>     Documents and Settings [C:\Users]
Regards. . .
jcgriff2
EDIT: What is the fill path and file name of the file from Power Producer? Does the app run OK otherwise under Vista (i.e., can you create new files)?
Old 12-15-2008   #5 (permalink)
MT
> >>> producing!!
Thanks guys - I did read in another post that the documents and settings
folder in XP is now the "user" folder in Vista.
But is there any way around this junction point so I can add the folder to
the C drive and not have it moved to the user folder???
Old 12-15-2008   #6 (permalink)
Richard Urban
You can not change the basic parameters of the operating system. Go to the
manufacturers web site of the program that is misbehaving and see if they
have an update to solve your problem.
Richard Urban
Microsoft MVP
Windows Desktop Experience
"MT" <MT@xxxxxx> wrote in message
news:4D915139-0814-41CF-84F0-A44970CF83EB@xxxxxx
>> >>> and
>> >>> Power
>> >>> Windows
>> >>> producing!!
>> >>> these
>> >that
>> >why
>> >Documents
>> >same
Old 12-15-2008   #7 (permalink)
Richard Urban
Check here for updates:
http://www.cyberlink.com/multi/downl...hes_3_ENU.html
Richard Urban
Microsoft MVP
"Richard Urban" <richardurbanREMOVETHIS@xxxxxx> wrote in message
news:%2326nsCpXJHA.4852@xxxxxx
> Richard Urban
> Microsoft MVP
>>> >>> and
>>> >>> Power
>>> >>> Windows
>>> >>> can
>>> >>> producing!!
>>> >>> these
>>> >that
>>> >why
>>> >Documents
>>> >same
>> to
Old 12-17-2008   #8 (permalink)
+Bob+
On Mon, 15 Dec 2008 03:39:39 -0500, "Richard Urban"
[top-post corrected]
I beg to differ. Unless MS hardcoded something (bad coding on their
part) you should be able to point D & S anywhere. That's the whole
point of a logical name (aka junction point in MS terminology).
Old 02-10-2009   #9 (permalink)
Vista Home Basic x86
Thanks,
MT
looking for.
I'm not sure if this will work for sure for all Vista users, but this certainly worked for me:
1) Open the C:\ drive in Explorer
2) Click Tools >> Folder Options >> View
3) On the list, check the box "Show Hidden Files and Folders" and UNcheck the box
"Hide protected operating system files"
4) Click "OK"
5) Now the the "Documents and Settings" folder is visible, right-click it and go to Properties
6) On the "Security" tab, click Edit, and change the owner of the folder to Administrators
7) Now, you shold be able to delete the "Documents and Settings" folder, and create your own, unprotected and fully-usable folder of the same name.
I hope this works for you
Would Like to create a "My Documents" Folder General Discussion
UAC - wont allow user who is administrator to access "documents and settings" folder ? Vista file management
Can you delete an old "documents and settings" folder? Vista General
Trying to remove an old "documents and settings" folder. Vista General
Documents and Settings folder "Access Denied" Vista General
